It appears there is an extra “\” …\AutoCAD 2013 – English\R19.0\enu\\Support\.
I don’t know if this is causing the error or not.
I tried these articles but everything checked out.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9579121&linkID=9240617 and http://support.microsoft.com/kb/886549
Not sure what to do next.
Solved by MarioVanceti. Go to Solution.
Thank you for your reply – I was just wondering what to do with this problem: “no properties for the selected objects”. Solution for me was to uninstall Acad2014, disabling roaming profiles and installed it again – no Error 1606 during installation and the problem with properties seems to be fixed – so your solution is working fine. Thank you again
I was able to solve the problem with the following solution
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
Resolution:-
Steps to resolve :
I had not thought to check the registry. My computer currently has two HHD running in raid 1 for data and a SSD for OS and programs. After correcting file paths, everyhting finally worked.
The correct solution is this
as described in the post dated 07-26-2013 12:43 AM
Please accept that as a valid solution
I have this 1606 error after upgrading to Windows 10. I have tried most of the solutions discussed in these messages and none have worked. I would like to try your solution, but I don't know how to disable roaming profiles. Can you tell me how to do this, please?
