Error 1606. Could not access network location Setup.
msmallmn
Message 1 of 26
msmallmn
It appears there is an extra “\” …\AutoCAD 2013 – English\R19.0\enu\\Support\.
I don’t know if this is causing the error or not.
I tried these articles but everything checked out.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=9579121&linkID=9240617 and http://support.microsoft.com/kb/886549
Not sure what to do next.
Replies (25)
Message 21 of 26
Thank you for your reply – I was just wondering what to do with this problem: “no properties for the selected objects”. Solution for me was to uninstall Acad2014, disabling roaming profiles and installed it again – no Error 1606 during installation and the problem with properties seems to be fixed – so your solution is working fine.  Thank you again
Message 22 of 26
wppdev
I was able to solve the problem with the following solution
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
  • Go to run.
  • Type ‘regedit’ click ‘ok’. The Registry Editor window opens.
  • Follow the path given below.
  • [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
  • Check the location for “Common Documents”, It will be pointing to a non-existent location
  • Eg. "Common Documents"="C:\\Users\\Public\\Documents"
  • Change the value data of common document as:
  • "Common Documents"="d:\\Users\\Public\\Documents"  (or any valid location)
  • OR create that non-existent folder
  • Run AutoCAD 2014 setup again
Message 23 of 26
Re: Error 1606. Could not access network location Setup.
07-26-2013 12:43 AM in reply to: msmallmn
Resolution:-
Steps to resolve :
  • Go to run.
I had not thought to check the registry. My computer currently has two HHD running in raid 1 for data and a SSD for OS and programs. After correcting file paths, everyhting finally worked.
Message 24 of 26
msmallmn
I just ended up creating a non-roaming profile on my machine. That solved the install issue for me.
______________________________________________________
This email has been scanned by MessageLabs
Message 25 of 26
wppdev
The correct solution is this
as described in the post dated 07-26-2013 12:43 AM
Please accept that as a valid solution
Message 26 of 26
edarchitect
I have this 1606 error after upgrading to Windows 10.  I have tried most of the solutions discussed in these messages and none have worked.  I would like to try your solution, but I don't know how to disable roaming profiles.  Can you tell me how to do this, please?
