Installation & Licensing
Active Member
Message 1 of 16 (12,200 Views)
Accepted Solution
Error 1606:Could not access network location Autodesk\Autocad 2014\R19.1
12200 Views, 15 Replies
04-22-2013 01:56 PM
Hi to everyone is couple of days than i try to install Autocad 2014  on windows 8 64 bits with not success everytime i tried i always get the same error as the picture:
I tried many things as i so in this forum as i saw in other forum ect....
I tried to check the following registry keys:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
  and they are as the following pictures:
  • HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Explorer\User Shell Folders
and i check also that:
  • HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
And after i checked also the environment variables as you can see in the following picture:
I don't know what else do, i haven't other idea please i need a quick help to fix my problem!   :smileysad:
Active Member
Message 2 of 16 (12,155 Views)
Re: Error 1606:Could not access network location Autodesk\Autocad 2014\R19.1
04-23-2013 01:26 PM in reply to: tonyv1978
I forget to say that i all ready try to install Autocad 2014 "run as Administrator" and the user where i'm loged is also administrator i also tried to create a new user with administrator rights and i tried to install autocad but no way always the same error.
What else i can do to fix this error, please i need help!!!!!
Active Member
Message 3 of 16 (12,106 Views)
04-25-2013 10:27 PM in reply to: tonyv1978
Please no one have an idea how to fix the problem, i need urgently a solution.
Member
Message 4 of 16 (12,047 Views)
04-29-2013 03:45 AM in reply to: tonyv1978
Hi, I have exactly the same problem:
Same OS, same error messages, same countermeasures with no success.
I checked the availability of paths and my write permissions etc.
I have placed the setup on the local hard disc in addition.
No chance to get the Installation done.
Has anybody an idea?
Active Member
wppdev
Message 5 of 16 (11,942 Views)
05-05-2013 11:43 PM in reply to: tonyv1978
same issue here
thos works well on Windoes 7 32 bit
but for Windows 7 64 bit
cannot install AutoCAD 2014
I tried it on 4 machines
everywhere same problem
thought I downladed the wrong/incomplete installer
downloaded it again, same problem
the user has all admin rights, everything seems fine
same problem
can anyone help!!!!
Member
Message 6 of 16 (11,939 Views)
05-05-2013 11:53 PM in reply to: tonyv1978
what I would like to add:
our CAD-workstation has an SSD (solid state disk) just for the operating system and the program data.
ALL user data ist stored on a second standard hard-disk. (D:\)
Is there a problem with different hard-drives for user-Data and programm data?
Member
Message 7 of 16 (11,898 Views)
05-07-2013 03:56 AM in reply to: mediplanGmbH
I also have the problem with the same configuration, SSD and D data drive.
Active Member
Message 8 of 16 (11,813 Views)
05-10-2013 02:20 PM in reply to: tonyv1978
Hi, to everyone, seem to be that also other peoples has the same problem but until now no solution i hope to see soon some advice, and i wish that i and the other we can find the solution for our problem.
Thank's in advance to everyone.   :smileyhappy:
Member
Message 9 of 16 (11,797 Views)
05-11-2013 01:07 PM in reply to: tonyv1978
sorry you are having the same problem, me too.
are your computers also SSD with User files going to seperate drive?
Has anyone reported this on subscription services?
Active Member
Message 10 of 16 (11,787 Views)
05-12-2013 03:13 AM in reply to: mike.monical
Yes, the hard drive on my laptop is SSD and inìs devide in 2 partition (C,D) the partition C is where is installed the OS and all the programs, and the partition D is where is saved the USER folders.
I never report this problem to subscription services.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
