I am receiving this issue when installing on Windows 7 x64 Enterprise. I am unable to get past the first AutoDesk install, which is SketchBook. It installs the pre-req software but then fails during SketchBook. I am attaching the logs of the install of SketchBook and AutoDesk as a whole.
Yep, I see the error.
Product: Autodesk SketchBook Designer 2014 -- Error 1308.Source file not found: C:\AutoDesk\Img\x64\SBD\Program Files\Autodesk\SketchBookDesigner2014\bin\Help\de-de\._Page5.png. Verify that the file exists and that you can access it.
You might have to redownload. You might also try unchecking Sketchbook and installing the rest for now.
Hm.. I made an initial copy of my deployment. Let me make sure this file is in it before I create a new deployment from the USB stick.
It was working on my local test bench but not working for the producrtion level. Maybe the file copy got messed up somewhere.
