Installation & Licensing
Error 1603 w/ AutoDesk Academy 2014 Install
2 REPLIES 2
254 Views, 2 Replies
I am receiving this issue when installing on Windows 7 x64 Enterprise.  I am unable to get past the first AutoDesk install, which is SketchBook.  It installs the pre-req software but then fails during SketchBook.  I am attaching the logs of the install of SketchBook and AutoDesk as a whole.
2 REPLIES 2
TravisNave
Yep, I see the error.
Product: Autodesk SketchBook Designer 2014 -- Error 1308.Source file not found: C:\AutoDesk\Img\x64\SBD\Program Files\Autodesk\SketchBookDesigner2014\bin\Help\de-de\._Page5.png.  Verify that the file exists and that you can access it.
 You might have to redownload.  You might also try unchecking Sketchbook and installing the rest for now.
Autodesk Forums:
in reply to: TravisNave
Hm..  I made an initial copy of my deployment.  Let me make sure this file is in it before I create a new deployment from the USB stick.
It was working on my local test bench but not working for the producrtion level.  Maybe the file copy got messed up somewhere.
Administrator Productivity
