Installation & Licensing
Error 1603 and 1619 when installing Revit 2014?
5 REPLIES 5
maurane.vanmoll
3034 Views, 5 Replies
I tried to install Revit 2014 (student version), but at the end of the installation I got a message saying that 'some products failed to install', which seems to mean ALL failed to install.
I really need this program to work, so I hope someone knows a solution?
This is the setup log file I got:
2013/11/1:11:04:27 Maurane MAURANE === Setup started on MAURANE by Maurane ===
2013/11/1:11:04:27 Maurane MAURANE Path_Length: 149
2013/11/1:11:04:27 Maurane MAURANE Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/11/1:11:04:27 Maurane MAURANE Launch
2013/11/1:11:04:27 Maurane MAURANE CommandLine /url "http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/Autodesk_Revit_2014_English_Win_32-64... /SN 900-42547059 /PK 829F1 /student /skipEULA /akamai /auth /sid
2013/11/1:11:04:27 Maurane MAURANE Current Directory C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp
2013/11/1:11:11:35 Maurane MAURANE === Setup ended ===
2013/11/1:11:04:34 Maurane MAURANE === Setup started on MAURANE by Maurane ===
2013/11/1:11:04:34 Maurane MAURANE Path_Length: 149
2013/11/1:11:04:34 Maurane MAURANE Current Directory C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp
2013/11/1:11:04:34 Maurane MAURANE Launch
2013/11/1:11:04:39 Maurane MAURANE Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:11:35 Maurane MAURANE Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:11:35 Maurane MAURANE Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\Setup\RevitSetup.dll
2013/11/1:11:11:35 Maurane MAURANE Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/11/1:11:11:35 Maurane MAURANE PageOpen LaunchDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen LicenseDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen ProductInfoDialog
2013/11/1:11:17:15 Maurane MAURANE PageOpen ProductSelectionDialog2
2013/11/1:11:19:46 Maurane MAURANE PageOpen FullProgressDialog
2013/11/1:11:19:47 Maurane MAURANE Download Play VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:14 Maurane MAURANE Download Complete VCREDIST2005X64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:14 Maurane MAURANE Installing Microsoft Visual C++ 2005 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2005\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Maurane\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/11/1:11:20:56 Maurane MAURANE Install Microsoft Visual C++ 2005 Redistributable (x64) Succeeded
2013/11/1:11:20:57 Maurane MAURANE Download Play KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:58 Maurane MAURANE Download Complete KB958314ATLX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:20:58 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:21:08 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/11/1:11:21:09 Maurane MAURANE Download Play KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:08 Maurane MAURANE Download Complete KB958314MFCX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:08 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:22:31 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/11/1:11:22:32 Maurane MAURANE Download Play KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:40 Maurane MAURANE Download Complete KB958314CRTX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:40 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:22:58 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/11/1:11:22:59 Maurane MAURANE Download Play KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:59 Maurane MAURANE Download Complete KB958314OPENMPX86 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:22:59 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:23:15 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/11/1:11:23:16 Maurane MAURANE Download Play KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:23:17 Maurane MAURANE Download Complete KB958314ATLX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:23:17 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (ATL) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:23:26 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/11/1:11:23:27 Maurane MAURANE Download Play KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:24:34 Maurane MAURANE Download Complete KB958314MFCX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:24:34 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (MFC) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:24:56 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/11/1:11:24:58 Maurane MAURANE Download Play KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:06 Maurane MAURANE Download Complete KB958314CRTX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:06 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (CRT) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:25:26 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/11/1:11:25:27 Maurane MAURANE Download Play KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:28 Maurane MAURANE Download Complete KB958314OPENMPX64 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:25:28 Maurane MAURANE Installing Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64): ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:25:44 Maurane MAURANE Install Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/11/1:11:25:45 Maurane MAURANE Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:26:43 Maurane MAURANE Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:11:26:43 Maurane MAURANE Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2013/11/1:11:27:23 Maurane MAURANE Install DirectX® Runtime Succeeded
2013/11/1:11:27:23 Maurane MAURANE Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:11:28:19 Maurane MAURANE Install FaroSDK Succeeded
2013/11/1:11:28:20 Maurane MAURANE Download Play RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:14:04:56 Maurane MAURANE Download Complete RVT2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:14:04:56 Maurane MAURANE Installing Autodesk® Revit® 2014: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2014\x64\en-us\RVT2014\RVT2014.mst;C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\x64\RVT2014\RVT2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:10:48 Maurane MAURANE Install Autodesk® Revit® 2014 Succeeded
2013/11/1:16:10:51 Maurane MAURANE Download Play RVT2014_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:13:49 Maurane MAURANE Download Complete RVT2014_en-us http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:13:50 Maurane MAURANE Installing Autodesk® Revit® 2014 Language Pack: TRANSFORMS="C:\Users\Maurane\AppData\Local\Temp\_AI3B0.tmp\_la4B1C.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=0 SETUP_ISLANGUAGEPACK=1 SETUP_PRODUCTDEPENDENCIES=";;;" MUIHIDEARP=1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:14:11 Maurane MAURANE Install Autodesk® Revit® 2014 Language Pack Succeeded
2013/11/1:16:14:12 Maurane MAURANE Installing Autodesk Workflows 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:14:18 Maurane MAURANE Install Autodesk Workflows 2014 Succeeded
2013/11/1:16:14:20 Maurane MAURANE Download Play CM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:22:41 Maurane MAURANE Download Complete CM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:22:42 Maurane MAURANE Installing Autodesk Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:23:27 Maurane MAURANE Install Autodesk Material Library 2014 Succeeded
2013/11/1:16:23:28 Maurane MAURANE Download Play CMILB2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:38:46 Maurane MAURANE Download Complete CMILB2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:16:38:46 Maurane MAURANE Installing Autodesk Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:16:39:16 Maurane MAURANE Install Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/1:16:39:19 Maurane MAURANE Download Play CMILL2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:17:14:48 Maurane MAURANE Download Complete CMILL2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:17:14:48 Maurane MAURANE Installing Autodesk Material Library 2014 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2014" SETUP_PACKAGECODE={7346B4A0-1400-0500-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/11/1:17:15:18 Maurane MAURANE Install Autodesk Material Library 2014 - Low Image Library Succeeded
2013/11/1:17:15:21 Maurane MAURANE Download Play CMILM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:31 Maurane MAURANE Download Error CMILM2014 <B>Connection has expired.</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:32 Maurane MAURANE Download Aborted CMILM2014 http://studentsdownload.autodesk.com/SWDLDNET3/2014/RVT/WI/EDU/{33292DAC-8423-4A6E-83C1-899C0C4F2E7E...
2013/11/1:18:21:32 Maurane MAURANE Install Autodesk Material Library 2014 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2013/11/1:18:21:54 Maurane MAURANE Rollback Autodesk Material Library 2014 - Low Image Library Succeeded
2013/11/1:18:22:12 Maurane MAURANE Rollback Autodesk Material Library 2014 - Base Image Library Succeeded
2013/11/1:18:22:46 Maurane MAURANE Rollback Autodesk Material Library 2014 Succeeded
2013/11/1:18:22:50 Maurane MAURANE Rollback Autodesk Workflows 2014 Succeeded
2013/11/1:18:22:56 Maurane MAURANE Rollback Autodesk® Revit® 2014 Language Pack Succeeded
2013/11/1:18:30:46 Maurane MAURANE Rollback Autodesk® Revit® 2014 Succeeded
2013/11/1:18:30:54 Maurane MAURANE Rollback FaroSDK Succeeded
2013/11/1:18:30:54 Maurane MAURANE Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2013/11/1:18:31:02 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x64) Succeeded
2013/11/1:18:31:15 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x64) Succeeded
2013/11/1:18:31:24 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x64) Succeeded
2013/11/1:18:31:28 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x64) Succeeded
2013/11/1:18:31:36 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (OpenMP) (x86) Succeeded
2013/11/1:18:31:43 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (CRT) (x86) Succeeded
2013/11/1:18:31:52 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (MFC) (x86) Succeeded
2013/11/1:18:31:57 Maurane MAURANE Rollback Microsoft Visual C++ 2008 KB958314 (ATL) (x86) Succeeded
2013/11/1:18:31:57 Maurane MAURANE Rollback Microsoft Visual C++ 2005 Redistributable (x64) Failed Installation aborted, Result=1619
5 REPLIES 5
avto
in reply to: maurane.vanmoll
Hello and welcome to the forums Maurane,
Based on the logs, downloading Autodesk Material Library 2014 – Medium Image Library fails during your Revit 2014 installation.
I would suggest to download Revit 2014 via Autodesk virtual agent interface:
  1. Go to http://www.autodesk.com.
  2. At the bottom of the page, beneath "Help and Support," click "Customer Service."
  3. Click the "Ask" button.
  4. In the Virtual Agent window, click "Download Links."
  5. Click on “Autodesk Revit Products”  and then ‘Autodesk Revit’
  6. Click the appropriate product to start downloading.
Then follow general installation steps we posted on our Up and Ready blog, click here.
Avto Chachava
Autodesk Product Support
Autodesk, Inc.
Thanks for your reply, I will definetely try that.
thefainster
in reply to: avto
i had that same problem but through inventor. lt downloaded fine but when it wanted to extract necessary files, it gave me "File Corrupt Error." what should I do? i'm using the Inventor Pro 2014 version also. please help
TravisNave
in reply to: thefainster
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
Autodesk Forums:
thefainster
in reply to: TravisNave
i did but it still doesn't want to download from that. i mean it downloads,
and it runs, but when it asks for a file placement, i give it right where
it's supposed to be but it still says File Corrupt Error
me
Administrator Productivity
