Installation & Licensing
bishara
Message 1 of 31 (3,202 Views)
Accepted Solution
Error 1603 and 1619 during Revit 2012 installation
3202 Views, 30 Replies
12-05-2011 07:37 AM
I am trying to install the student version of Revit 2012 on windows 7 and I through the serial number part, but as it installing, it just aborts.  When I look at the installation log, I see errors 1603 and 1619.  I check some solutions here and re-installing windows was what one person did, but I cannot do that.
Please help.
Product Support
hashim.mundol
Message 2 of 31 (3,189 Views)
Re: Error 1603 and 1619 during Revit 2012 installation
12-06-2011 06:34 AM in reply to: bishara
1603 is generic permission error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persists, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
bishara
Message 3 of 31 (3,178 Views)
12-06-2011 10:56 AM in reply to: bishara
Hi Hashim,
Thanks for the suggestion, but I tried the diagnostic mode and it still failed.  I attached here the installation log so you can see the errors.
Please let me know if you have ideas.
Thanks!
Product Support
hashim.mundol
Message 4 of 31 (3,159 Views)
12-07-2011 12:30 AM in reply to: bishara
Please try
http://forums.autodesk.com/t5/Installation-Licensing/Autocad-Electrical-2012-won-t-install/m-p/32442...
Hashim Mundol
Autodesk, Inc.
bishara
Message 5 of 31 (3,144 Views)
12-07-2011 08:21 AM in reply to: bishara
Still not working for some reason.  I looked at my control panel and it shows Visual C++ 2005 Redist to be installed.
I have attached the new installation log.
This time when I tried to install, a popup came up right before installation attempted.  The popup said windows installer has failed.
Product Support
hashim.mundol
Message 6 of 31 (3,141 Views)
12-07-2011 08:27 AM in reply to: bishara
error in the log is still about
Installing Microsoft Visual C++ 2005 SP1 Redistributable
Please uninstall all VC++ components and install it manually as described in the other posts
Hashim Mundol
Autodesk, Inc.
bishara
Message 7 of 31 (3,132 Views)
12-07-2011 01:29 PM in reply to: bishara
Hi Hashim,
I tried it.  I uninstalled all VC++ components and then installed from the microsoft website.
It is still providing the same errors.  Could I be installing the wrong versions?  I am using these links:
http://www.microsoft.com/download/en/details.aspx?id=5555
http://www.microsoft.com/download/en/details.aspx?id=5638
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=29
Best,
Bishara
Product Support
hashim.mundol
Message 8 of 31 (3,122 Views)
12-08-2011 04:39 AM in reply to: bishara
Assuming the error is still about VC++ runtime
Links are almost correct for 32 bit OS. (except for the 2008 one)
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5638
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5582
http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=5555
Have you done a complete windows update ?
Have these installations gone through successfullly ? if yes
Another option would be to clean all the VC++ components and let the revit installer do this part.
If it fails, please post the detailed logs from the %temp% folder for the vc++ part.
Hashim Mundol
Autodesk, Inc.
bishara
Message 9 of 31 (3,114 Views)
12-08-2011 08:47 AM in reply to: bishara
Still not working.
I removed all vc++ components and let revit install them.  It did not work.  It only installed 2005 and 2008 and then failed.
Then when I try to get you the temp files, the only folder in the Temp folder that is related to VC++, is VC++2010.  And there are some 2010 related text docs, but I can't open them????  It says access denied.
Can I get in touch with anyone at Autodesk to help me?  Maybe with a shared screen to solve the issue?
I really need to get this installed so I can do some work for my class.
Thanks.
Product Support
hashim.mundol
Message 10 of 31 (3,112 Views)
12-08-2011 08:50 AM in reply to: bishara
Were you able to install VC++ 2010 manually ?
Hashim Mundol
Autodesk, Inc.
Announcements
Need installation help?
