• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Expert Elite*
    DarrenP
    Re: Error 1603 and 1619 during Revit 2012 installation
    12-12-2011 05:50 PM in reply to: bishara
    reformating your harddrive hopefully you know what means
    Please use plain text.
    bishara
    12-12-2011 05:53 PM in reply to: DarrenP
    i dont
    *Expert Elite*
    DarrenP
    12-12-2011 05:56 PM in reply to: bishara
    you need to take it to a computer shop and get them to do it for you
    Product Support
    12-12-2011 11:58 PM in reply to: bishara
    Please try this solution on the keys mentioned in the Error log earlier
    http://usa.autodesk.com/getdoc/id=TS16508079
    Creating a new admin user will not help as this registry key is system related
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    Autodesk, Inc.
    bishara
    12-13-2011 05:41 AM in reply to: DarrenP
    Hashim,
    This is similar to the previous solution you provided me.  When I try steps 5 and 6 in the solution you just provided me, it does not work.  I check the boxes and click apply.  As soon as I click apply, the boxes uncheck themselves.
    I tried many times...
    *Expert Elite*
    DarrenP
    12-13-2011 05:43 AM in reply to: DarrenP
    thats an OS issue
    you should try what i suggested before
    bishara
    12-13-2011 05:45 AM in reply to: DarrenP
    My computer is only about 6 months old with windows 7.  Would it really need that?
    Product Support
    12-13-2011 07:45 AM in reply to: bishara
    It is important that you change the ownership of the hive before changing the permission. Here it is bit more clearer.
    http://www.okino.com/conv/changing_windows_registry_permissions.htm
    Hashim Mundol
    Autodesk, Inc.
    bishara
    12-13-2011 12:31 PM in reply to: DarrenP
    IT FINALLY WORKED!!!
    I did your suggestion along with some help from Geek Quad at Best Buy.  Thanks so much for your help!
    New Member
    04-04-2012 04:46 AM in reply to: bishara
    Hello
    Please could you exactly describe  what you have done to correct the error 1603 and 1619, because I have the similiar problem and I can't fix it!!!
    Greets,
    Michaela
