Installation & Licensing
Error 1603 and 1619 during Revit 2012 installation
30 REPLIES 30
Message 1 of 31
bishara
3917 Views, 30 Replies
I am trying to install the student version of Revit 2012 on windows 7 and I through the serial number part, but as it installing, it just aborts.  When I look at the installation log, I see errors 1603 and 1619.  I check some solutions here and re-installing windows was what one person did, but I cannot do that.
Please help.
30 REPLIES 30
Message 21 of 31
DarrenP
in reply to: bishara
reformating your harddrive hopefully you know what means
DarrenP
Message 22 of 31
bishara
in reply to: DarrenP
i dont
Message 23 of 31
DarrenP
you need to take it to a computer shop and get them to do it for you
DarrenP
Message 24 of 31
hashim.mundol
Please try this solution on the keys mentioned in the Error log earlier
http://usa.autodesk.com/getdoc/id=TS16508079
Creating a new admin user will not help as this registry key is system related
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Message 25 of 31
bishara
Hashim,
This is similar to the previous solution you provided me.  When I try steps 5 and 6 in the solution you just provided me, it does not work.  I check the boxes and click apply.  As soon as I click apply, the boxes uncheck themselves.
I tried many times...
Message 26 of 31
DarrenP
thats an OS issue
you should try what i suggested before
DarrenP
Message 27 of 31
bishara
My computer is only about 6 months old with windows 7.  Would it really need that?
Message 28 of 31
hashim.mundol
It is important that you change the ownership of the hive before changing the permission. Here it is bit more clearer.
http://www.okino.com/conv/changing_windows_registry_permissions.htm
Hashim Mundol
Message 29 of 31
bishara
IT FINALLY WORKED!!!
I did your suggestion along with some help from Geek Quad at Best Buy.  Thanks so much for your help!
Message 30 of 31
marianne.kopp
Hello
Please could you exactly describe  what you have done to correct the error 1603 and 1619, because I have the similiar problem and I can't fix it!!!
Greets,
Michaela
Message 31 of 31
planemaster92
I had the same problem too.  I tried the diagnostic mode with no help, then I tried to manually install vc++ 2005.  That also didn't help.  So I uninstalled vc++ 2005 and ran revit setup.  This time it installed the vc++ 2005 but crashed when it came to vc++ 2008.  So I then decided that it wanted to install them all from scratch and proceeded to uninstall all versions of vc++ (both x86 and x64).  Once done I ran the setup again and it has just successfully installed.  So if you are having problems with the vc++ error then uninstall all instances of it including any that may have been installed by revit.
Administrator Productivity
