Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Error 1603 and 1619 during Revit 2012 installati on
- Highlight
- Email to a Friend
I am trying to install the student version of Revit 2012 on windows 7 and I through the serial number part, but as it installing, it just aborts. When I look at the installation log, I see errors 1603 and 1619. I check some solutions here and re-installing windows was what one person did, but I cannot do that.
Please help.
Re: Error 1603 and 1619 during Revit 2012 installati on
- Highlight
- Email to a Friend
1603 is generic permission error, please try to install the software in diagnostics mode as described here
http://usa.autodesk.com/getdoc/id=TS75218
If the issue persists, please post the all the log files from the %temp% folder (start->run/search->type %temp% ->Enter) as a zip file.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Hashim,
Thanks for the suggestion, but I tried the diagnostic mode and it still failed. I attached here the installation log so you can see the errors.
Please let me know if you have ideas.
Thanks!
- Highlight
- Email to a Friend
Please try
Hashim Mundol
Autodesk, Inc.
- Highlight
- Email to a Friend
Still not working for some reason. I looked at my control panel and it shows Visual C++ 2005 Redist to be installed.
I have attached the new installation log.
This time when I tried to install, a popup came up right before installation attempted. The popup said windows installer has failed.
- Highlight
- Email to a Friend
error in the log is still about
Installing Microsoft Visual C++ 2005 SP1 Redistributable
Please uninstall all VC++ components and install it manually as described in the other posts
Hashim Mundol
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Hashim,
I tried it. I uninstalled all VC++ components and then installed from the microsoft website.
It is still providing the same errors. Could I be installing the wrong versions? I am using these links:
http://www.microsoft.com/download/en/details.aspx?
Best,
Bishara
- Highlight
- Email to a Friend
Assuming the error is still about VC++ runtime
Links are almost correct for 32 bit OS. (except for the 2008 one)
Have you done a complete windows update ?
Have these installations gone through successfullly ? if yes
Another option would be to clean all the VC++ components and let the revit installer do this part.
If it fails, please post the detailed logs from the %temp% folder for the vc++ part.
Hashim Mundol
Autodesk, Inc.
- Highlight
- Email to a Friend
Still not working.
I removed all vc++ components and let revit install them. It did not work. It only installed 2005 and 2008 and then failed.
Then when I try to get you the temp files, the only folder in the Temp folder that is related to VC++, is VC++2010. And there are some 2010 related text docs, but I can't open them???? It says access denied.
Can I get in touch with anyone at Autodesk to help me? Maybe with a shared screen to solve the issue?
I really need to get this installed so I can do some work for my class.
Thanks.
- Highlight
- Email to a Friend
Were you able to install VC++ 2010 manually ?
Hashim Mundol
Autodesk, Inc.
