Hi, I'm trying to install the 30-Day Trial Version of Revit 2014, but I always end up with abort installation, here is the Installation Log:
2013/4/19:05:45:31 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:05:45:31 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:05:45:31 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:05:45:31 Charbel CHARBEL-PC Launch
2013/4/19:05:45:31 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:05:45:31 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp
2013/4/19:05:48:54 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:05:45:35 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:05:45:35 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:05:45:35 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp
2013/4/19:05:45:35 Charbel CHARBEL-PC Launch
2013/4/19:05:46:51 Charbel CHARBEL-PC Download Play SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:05:48:53 Charbel CHARBEL-PC Download Complete SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:05:48:53 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI9B14.tmp\Setup\RevitSetup.dll
2013/4/19:05:48:53 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:05:48:54 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:05:50:32 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:05:50:39 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:05:52:17 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:05:52:46 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:05:52:47 Charbel CHARBEL-PC Download Play VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:05:53:00 Charbel CHARBEL-PC Download Complete VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:05:53:00 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:05:53:15 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:05:53:15 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:05:53:50 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:06:06:13 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:06:06:13 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:06:06:13 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:06:06:13 Charbel CHARBEL-PC Launch
2013/4/19:06:06:13 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:06:06:13 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp
2013/4/19:06:06:21 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:06:06:16 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:06:06:16 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:06:06:16 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp
2013/4/19:06:06:16 Charbel CHARBEL-PC Launch
2013/4/19:06:06:17 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:06:06:18 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI3AFD.tmp\Setup\RevitSetup.dll
2013/4/19:06:06:19 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:06:06:20 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:06:06:30 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:06:06:35 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:06:08:31 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:06:09:18 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:06:09:18 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:06:09:18 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:06:09:29 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:06:09:30 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:06:10:01 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:15:57:21 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:15:57:21 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:15:57:21 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:15:57:21 Charbel CHARBEL-PC Launch
2013/4/19:15:57:21 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:15:57:21 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp
2013/4/19:15:59:17 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:15:57:24 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:15:57:24 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:15:57:24 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp
2013/4/19:15:57:24 Charbel CHARBEL-PC Launch
2013/4/19:15:59:17 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:15:59:17 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AI687C.tmp\Setup\RevitSetup.dll
2013/4/19:15:59:17 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:15:59:17 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:15:59:25 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:15:59:30 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:01:08 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:01:17 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:01:18 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:01:18 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:01:23 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:01:24 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:07:11 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:07:30 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:07:30 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:07:30 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:16:07:30 Charbel CHARBEL-PC Launch
2013/4/19:16:07:30 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:16:07:30 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp
2013/4/19:16:07:35 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:07:32 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:07:32 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:07:32 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp
2013/4/19:16:07:32 Charbel CHARBEL-PC Launch
2013/4/19:16:07:33 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:16:07:33 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AIB94A.tmp\Setup\RevitSetup.dll
2013/4/19:16:07:33 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:16:07:34 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:16:07:45 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:16:07:57 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:09:12 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:09:20 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:09:20 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:09:20 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:09:25 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:09:26 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:14:07 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:21:38 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:21:38 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:21:38 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/4/19:16:21:38 Charbel CHARBEL-PC Launch
2013/4/19:16:21:38 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/4/19:16:21:38 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp
2013/4/19:16:21:44 Charbel CHARBEL-PC === Setup ended ===
2013/4/19:16:21:41 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/4/19:16:21:41 Charbel CHARBEL-PC Path_Length: 149
2013/4/19:16:21:41 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp
2013/4/19:16:21:41 Charbel CHARBEL-PC Launch
2013/4/19:16:21:42 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/4/19:16:21:42 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AIAFBE.tmp\Setup\RevitSetup.dll
2013/4/19:16:21:42 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/4/19:16:21:43 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/4/19:16:21:55 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/4/19:16:22:00 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/4/19:16:24:12 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/4/19:16:24:30 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/4/19:16:24:30 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/4/19:16:24:30 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/4/19:16:24:38 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
2013/4/19:16:24:41 Charbel CHARBEL-PC PageOpen InstallCompleteDialog
2013/4/19:16:25:14 Charbel CHARBEL-PC === Setup ended ===
2013/5/23:00:05:44 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/5/23:00:05:44 Charbel CHARBEL-PC Path_Length: 149
2013/5/23:00:05:44 Charbel CHARBEL-PC Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US
2013/5/23:00:05:44 Charbel CHARBEL-PC Launch
2013/5/23:00:05:44 Charbel CHARBEL-PC CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/Autodesk_Revit_2014_English_Win_32-64bit_wi_en-US_S..." /akamai /auth authparam /sid SESSION_ID
2013/5/23:00:05:44 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp
2013/5/23:00:06:31 Charbel CHARBEL-PC === Setup ended ===
2013/5/23:00:05:48 Charbel CHARBEL-PC === Setup started on CHARBEL-PC by Charbel ===
2013/5/23:00:05:48 Charbel CHARBEL-PC Path_Length: 149
2013/5/23:00:05:48 Charbel CHARBEL-PC Current Directory C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp
2013/5/23:00:05:48 Charbel CHARBEL-PC Launch
2013/5/23:00:06:31 Charbel CHARBEL-PC Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/SETUP_x64.ta...
2013/5/23:00:06:31 Charbel CHARBEL-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Charbel\AppData\Local\Temp\_AICB8C.tmp\Setup\RevitSetup.dll
2013/5/23:00:06:31 Charbel CHARBEL-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2013/5/23:00:06:31 Charbel CHARBEL-PC PageOpen LaunchDialog
2013/5/23:00:06:41 Charbel CHARBEL-PC PageOpen LicenseDialog
2013/5/23:00:06:45 Charbel CHARBEL-PC PageOpen ProductInfoDialog
2013/5/23:00:08:38 Charbel CHARBEL-PC PageOpen ProductSelectionDialog2
2013/5/23:00:08:59 Charbel CHARBEL-PC PageOpen FullProgressDialog
2013/5/23:00:08:59 Charbel CHARBEL-PC Download Skipped VCREDIST2008SP1X64 http://trial2.autodesk.com/SWDLDNET3/2014/RVT/WI/{463919AA-242C-48FF-826E-75B97428E2E5}/VCREDIST2008...
2013/5/23:00:08:59 Charbel CHARBEL-PC Installing Microsoft Visual C++ 2008 SP1 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit 2014\3rdParty\x64\VCRedist\2008SP1\vcredist_x64.exe" /q
2013/5/23:00:09:06 Charbel CHARBEL-PC Install Microsoft Visual C++ 2008 SP1 Redistributable (x64) Failed Installation aborted, Result=1603
The only Microsoft Visual C++ 2008 SP1 Redistributable (x64) installed on my laptop is [ Microsoft Visual C++ 2008 Redistributable - x64 9.0.30729.17 ]
Is there any solution to this? I tried following the solutions I found in Googled but still nothing works:
- Turn off UAC
- Turn off Anti-Virus Software (mine is Avast)
- Uninstall the existing Microsoft Visual C++ 2008 SP1 Redistributable (x64) in 'Uninstall Program', re-reun installation, then let Autodesk install it during Revit installation
- Uninstall ALL other Microsoft Visual C++ then re-reun installation
- Create a [ C:\Temp ] folder
- Re-register [ msiexec.exe ] in [command prompt] and type [ msiexec.exe/unreg ], then type [ msiexec.exe -regserver ]
- A combination of everything above in [ Safe Mode with Internet ]
Please help me, I really need to study Revit within the next 30 days. And I don't want to reformat/reset my laptop because I can't afford to have all my files there deleted & I couldn't afford to get an external hard drive right now to back-up my files & saving them in a blank DVD-R would take soo much time. Thank you in advance to anyone who can help me.
Remove the prerequisite check for this in the setup.ini. See my follow up on this thread:
http://forums.autodesk.com/t5/Installation-Licensing/Install-NET-Framework-Language-Pack-Failed-Inst...
