Installation & Licensing
Error [-15.570.0]- "A valid license could not be obtained..."
6 REPLIES 6
7990 Views, 6 Replies
 Hi all,
I'm using Inventor 2011 on Windows 7. When I try to start Inventor, I see a dialog box informing me that "Your application was not able to obtain a license because the FLEXnet license server manager could not determing where to find the licensing data it needs." Upon providing the location of the license file, I receive the error "A valid license could not be obtained by the network license manager," with Error [-15.570.0]. I've edited the hosts file, and I've also tried the solution shown here: http://208.74.205.69/t5/Installation-Licensing/error-15-570-0/td-p/2805252. I've had no luck. Any thoughts on other potential solutions to the problem? Thanks!
Andrew
6 REPLIES 6
emily.xu
TravisNave
For installations on Windows Vista/7 when the NLM is on Server 2008 or another Windows Vista/7 machine, then the -15 error is typically due to a connectivity error with IPv6. I have a KB on this issue in the forums.
For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Hmmm. I forgot to mention that the NLM is running on a Mac OS X server. So I don't think it's an IPv6 problem. I can ping the hostname from the client and I'm returned an IPv4-formatted IP. Any other possibilities? Thanks for the replies!
Andrew
TravisNave
Are you sure you have a valid adskflex vendor file and Autodesk license service created on your Mac?  Can you do a status that shows you have available Autodesk licenses?  You're probably better off moving to a Windows Server.
Autodesk Forums:
Everything should be there (it used to work just fine, and then something apparently happened that caused it to fail), unfortunately I don't have immediate access to the server to check. I'll talk to the guy who does tomorrow and see what I can find. Thanks!
Andrew
Just so everyone knows, I got the problem worked out. I reinstalled the NLM on a Windows 7 machine. I believe the issue involved the server host name on the Mac server expiring, but the reinstall fixed the problem without too much difficulty. Thanks for the help!
Andrew
Administrator Productivity
