Installation & Licensing
Error 1406 Could not write value to key
6 REPLIES 6
sbamufleh
9955 Views, 6 Replies
I get the following error when trying to install Civil 3D 2012 XP SP3
Error 1406. Could not write value to key \Software\Classes\CLSID\{00020820-0000-0000-C000-000000000046}\InprocServer32\11.0.0.0. Verify that you have sufficient access to that key, or contact your support personnal.
Faisal
6 REPLIES 6
Jason.Hickey
in reply to: sbamufleh
You will be much better served posting this question in the Installation and Licensing forum.
Jason Hickey
Premium Services Specialist
Autodesk, Inc.
hashim.mundol
Please try
http://usa.autodesk.com/getdoc/id=TS1069886
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
TravisNave
If this is due to an old Flash player, you can probably hit ignore about a dozen times and come out okay.  Update your Flash player.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Diequa
in reply to: TravisNave
I'll confirm that this works, even though it seems like the wrong thing to do.
TravisNave
in reply to: Diequa
Well, being that I supported this issue multiple times a day as well as went onsite and experienced it myself on customer machines, I think you'll probably be alright.  Smiley Very Happy The issue is due to a problem that Macromedia had with an old version of Flash.  You should consider upgrading your Adobe Flash plugins as well.  Once you ignore those dozen or so 1406 errors, you'll be on your way.  Smiley Wink
Autodesk Forums:
Is there a switch that can be applied to the install script (deployment shortcut) that will ignore all ignores like /I /QB?
Administrator Productivity
