• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    Error 1406 Could not write value to key
    1438 Views, 5 Replies
    01-10-2012 06:20 AM
    I get the following error when trying to install Civil 3D 2012 XP SP3
    Error 1406. Could not write value to key \Software\Classes\CLSID\{00020820-0000-0000-C000-000000000046}\InprocServer32\11.0.0.0. Verify that you have sufficient access to that key, or contact your support personnal.
    Faisal
    Please use plain text.
    Product Support
    Jason.Hickey
    Re: Error 1406 Could not write value to key
    01-10-2012 06:22 AM in reply to: mfaisal_i
    You will be much better served posting this question in the Installation and Licensing forum.
    Jason Hickey
    Premium Services Specialist
    Product Support
    01-12-2012 02:49 AM in reply to: mfaisal_i
    Please try
    http://usa.autodesk.com/getdoc/id=TS1069886
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    TravisNave
    01-12-2012 09:23 AM in reply to: mfaisal_i
    If this is due to an old Flash player, you can probably hit ignore about a dozen times and come out okay.  Update your Flash player.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Active Member
    01-17-2013 11:27 AM in reply to: TravisNave
    I'll confirm that this works, even though it seems like the wrong thing to do.
    TravisNave
    01-17-2013 11:44 AM in reply to: Diequa
    Well, being that I supported this issue multiple times a day as well as went onsite and experienced it myself on customer machines, I think you'll probably be alright.  :smileyvery-happy: The issue is due to a problem that Macromedia had with an old version of Flash.  You should consider upgrading your Adobe Flash plugins as well.  Once you ignore those dozen or so 1406 errors, you'll be on your way.  :smileywink:
    Travis Nave
