• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Product Support
    Error 1402 during uninstallation (Could not open key)
    10134 Views, 7 Replies
    03-02-2011 12:54 PM
    We have been getting this error occasionally come into support and when it finally happened on my computer, I decided to go though the solution and confirm that it does work.
    When you try to uninstall an AutoCAD based product, you will get the following error:
    Error 1402.  Could not open key:
    UNKNOWN\Components\Hex#\Hex#.  Verify that you have sufficient access to that key, or contact your support personnel.
    The solution is to change the permissions of the following folder in the Registry:
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components
    1. Right Click on Components select permissions.
    2. Click Advanced button.
    3. Select the Owner Tab
    4. Under Change owner to:  Select Administrators (Group) and Click Apply.
    5. Then Select Check box Replace owner on subcontainers and objects and Click Apply.
    6. Go to the Permissions tab, select the Check box:  Replace all child objects Permissions with inheritable permissions from this object and Click apply.  NOTE:  The wording maybe a bit different depending on your operating system.
    I have included a video on changing the permissions in Windows Vista & Windows 7.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Please use plain text.
    gf
    New Member
    Re: Error 1402 during uninstallation (Could not open key)
    08-11-2011 02:04 AM in reply to: david.lau
    Hi!
    Why does this happen in the first place?
    We had this happen by deleting the installationfiles from the install folder IMMEDIATLY AFTER the setup.exe returned, but there where still some parts of the install running which were launched by setup.exe.
    So the setup itself returned but not all started install tasks were finished. REALLY BAD design!
    Trying to just rerun the setup always failed with strange 'unable to install anchor service' errors which were caused by the '1402' errors during the installation because of messed up permissions by the prior (failed) installation.
    I would suggest you create a better and more resilient installation routine to prevent stuff like this from happening in the first place. Only tackling the symptoms does not help in the long run.
    Overall Autodesk software installation is still a PITA, but has improved over the years - Which does not mean that it is good right now, only shows how utterly horrible it has been in the past. Still a long way to go...
    Product Support
    09-28-2011 06:43 AM in reply to: david.lau
    I value your opinion.  This post was only meant to help solve a problem.
    David Lau
    New Member
    gnutt
    01-06-2012 10:10 AM in reply to: david.lau
    I started having issues with this aftern uninstalling all Autodesk products from a Windows 7 64 bit computer to reinstall clean.   I was trying to reinstall a package created on the server.  What I did was drilled down to the actual base .msi install package and started the install this way.  As a result, when there was an error on a class key, I deleted the class key altogether.  Then I hit retry and it recreated it and continued on.
    It seems as though the Autocad installer balks when it tries to create a registry key that already exists.
     Incidentally, changing the permissions on the keys had no effect.
    Distinguished Contributor
    03-10-2012 05:38 AM in reply to: gf
    After making the suggested changes this is what happens when I hit APPLY
    Registry Editor could not set owner on the key currently selected, or some of its subkeys.
    How can I proceed from here?
    *Expert Elite*
    TravisNave
    03-11-2012 08:17 PM in reply to: ~master
    Try it a few times.  If that doesn't work, go down and find each individual key that it cannot change and make the changes there.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16508079&linkID=9240617
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    03-12-2012 06:18 AM in reply to: david.lau
    Went ahead and did a complete re-install of the OS.
    Thanks for the suggestions.
    New Member
    brankoje57
    08-22-2012 05:20 AM in reply to: david.lau
    There is not such key in my registry.
    I use Win 7 Ultimate x64
    Please help.
