I'm a student from the netherlands and trying to instal autocad 2012.
Buth when i install autocad i get 2 errors:
(1)
Failed to find node: //configuration/connect/Vdrive in XML file:
C:/Program Files (c86)/Autodesk/ContentService/Connect.Service.exe.config, system error: -2147020584
When i click ok, he keep installing autocad. When he is installing 5/10 i get this error
(2)
Error 1402. Could not open key:
Unknown/components/D0BF41B233AF0AC6C4F1A79C8630ED3/7D2F3875100A9040102000060BECB6AB. Verify that you have a sufficient acces tot hat key, or contact your support personnel.
I downloaded several times from the autodesk site, buth i keep getting this errors.. and just because i'm reinstalling autocad???
Someone knows what i can do to fix this?
already got 2013 buth it needs many fixes.... so i want back to 2012, buth i cant ><
For your first question, please open the Control Panel > Programs and Features and verify that the Content Service is not currently installed. If you see this listed in the list of installed programs, please select it and uninstall it before installing AutoCAD 2012.
For the second question, 1402 error is generally you do not have sufficient access to read or write some register key. I would suggest you to use a user with admin right to install,the system default user "Administrator" would be better。And also, we have some solutions on such problem for your reference:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16508079&linkID=9240617
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10297059&linkID=9240617
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
