• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Distinguished Contributor
    Accepted Solution
    Error 1304 while creating a deployment
    226 Views, 6 Replies
    10-31-2012 12:11 PM
    i'm creating a deplyment out on the network but I receive the following 1304 error:
    I have full access rights to the root folder \\SLBF0004\Engineering\Cadapp\PDSP2013\deploy\64.
    Please use plain text.
    Distinguished Mentor
    Re: Error 1304 while creating a deployment
    10-31-2012 01:40 PM in reply to: cadfish1
    Try a shorter path to your deployment directory.
    John Retzlaff
    Product Support
    11-01-2012 07:30 AM in reply to: cadfish1
    Cookml,
    Hello. This type of error is often due to path depth. I believe you may be running into windows depth limitations.
    http://upandready.typepad.com/up_and_ready/2011/05/error-1603-and-1304-during-deployment-creation-re...
    http://upandready.typepad.com/up_and_ready/2012/04/autodesk-suites-2013-deployment-path-can-easily-e...
    If you shorten your deployment path you may complete.
    Thank you for taking part in our community!
    David Dembkoski
    Product Support Specialist
    Autodesk Product Support
    11-01-2012 10:49 AM in reply to: dembkod
    \\slbf0004\Engineering\Cadapp\PDSP2013\deploy
    Thanks John and David, you were right.  However my path is pretty short already.  It's difficult for me to make much shorter.  \\slbf0004\Engineering is the root on the drive which can't be changed and represent almost half the number of characters in the original path.  The remaining folder names in the part are all pretty short.  Do you have any recommendations on how I can structure the folder on this drive?
    Product Support
    11-01-2012 10:54 AM in reply to: cadfish1
    Cadfish1,
    Hello. You should be able to know with a simple test. Go shorter. \\deploy\ and try to build to this folder. Your existing path takes up 20% of the Microsoft limit currently.
    David Dembkoski
    11-01-2012 11:01 AM in reply to: dembkod
    Are you saying the path should be \\slbf0004\engineering\deploy?  I did something similar and it worked but I can use that folder because I have several deployments (vault, acad/Inventor, algor) in both 64 and 32 bit.
    *Expert Elite*
    TravisNave
    11-02-2012 08:44 AM in reply to: cadfish1
    Don't worry about the PHYSICAL path, if you have some sort of ISO policy that designates folder locations.  You can share the last folder itself \Deploy and the UNC path will just be \\slbf0004\deploy even if the physical path location is deep like your original path.  The misconception about folder location and shares is that you have to share the top level folder and this is not correct.  Place it where you want it to go, and share the last folder.  The whole point of shares is to make it easy to get to a folder location on the network.  If you still have to traverse a million folders, you're defeating the purpose.  Share the last folder.  Problem solved.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
