Installation & Licensing
Distinguished Contributor
cadfish1
Message 1 of 7 (311 Views)
Error 1304 while creating a deployment
311 Views, 6 Replies
10-31-2012 12:11 PM
i'm creating a deplyment out on the network but I receive the following 1304 error:
I have full access rights to the root folder \\SLBF0004\Engineering\Cadapp\PDSP2013\deploy\64.
Distinguished Mentor
john.retzlaff
Message 2 of 7 (301 Views)
Re: Error 1304 while creating a deployment
10-31-2012 01:40 PM in reply to: cadfish1
Try a shorter path to your deployment directory.
John Retzlaff
Product Support
dembkod
Message 3 of 7 (272 Views)
11-01-2012 07:30 AM in reply to: cadfish1
Cookml,
Hello. This type of error is often due to path depth. I believe you may be running into windows depth limitations.
http://upandready.typepad.com/up_and_ready/2011/05/error-1603-and-1304-during-deployment-creation-re...
http://upandready.typepad.com/up_and_ready/2012/04/autodesk-suites-2013-deployment-path-can-easily-e...
If you shorten your deployment path you may complete.
Thank you for taking part in our community!
David Dembkoski
Product Support Specialist
Autodesk Product Support
David Dembkoski
cadfish1
Message 4 of 7 (259 Views)
11-01-2012 10:49 AM in reply to: dembkod
\\slbf0004\Engineering\Cadapp\PDSP2013\deploy
Thanks John and David, you were right.  However my path is pretty short already.  It's difficult for me to make much shorter.  \\slbf0004\Engineering is the root on the drive which can't be changed and represent almost half the number of characters in the original path.  The remaining folder names in the part are all pretty short.  Do you have any recommendations on how I can structure the folder on this drive?
Product Support
dembkod
Message 5 of 7 (257 Views)
11-01-2012 10:54 AM in reply to: cadfish1
Cadfish1,
Hello. You should be able to know with a simple test. Go shorter. \\deploy\ and try to build to this folder. Your existing path takes up 20% of the Microsoft limit currently.
David Dembkoski
David Dembkoski
cadfish1
Message 6 of 7 (255 Views)
11-01-2012 11:01 AM in reply to: dembkod
Are you saying the path should be \\slbf0004\engineering\deploy?  I did something similar and it worked but I can use that folder because I have several deployments (vault, acad/Inventor, algor) in both 64 and 32 bit.
TravisNave
Message 7 of 7 (239 Views)
11-02-2012 08:44 AM in reply to: cadfish1
Don't worry about the PHYSICAL path, if you have some sort of ISO policy that designates folder locations.  You can share the last folder itself \Deploy and the UNC path will just be \\slbf0004\deploy even if the physical path location is deep like your original path.  The misconception about folder location and shares is that you have to share the top level folder and this is not correct.  Place it where you want it to go, and share the last folder.  The whole point of shares is to make it easy to get to a folder location on the network.  If you still have to traverse a million folders, you're defeating the purpose.  Share the last folder.  Problem solved.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
