• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    TravisNave
    Re: Error 1304 or 2350 When Creating a Deployment for Autodesk 2011 Products
    08-09-2012 01:04 PM in reply to: spm5
    No, the metaphor is more like a car that is designed to run on gasoline but you'd rather run on electric.  There's nothing that can be done during this release except to wait for the flex-fuel vehicle to be released.  Thus, the share path length recommendation has everything to do with this conversation because unless you do so, you cannot install it.  Period.
    Regardless, the limitation is on Microsoft Windows, and not Autodesk.  Thus any software manufacture would potentially run into this same issue.  Hopefully, this will not be an issue moving forward.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    Member
    MatthiasFostel
    08-09-2012 01:04 PM in reply to: bryce.thelin
    I'd like to bring up the fact that the latest 2013 suite we are rolling out recently is even worse than before.
    I was able to shorten a path length with the 2012 suite and get around the character limit. But with 2013, it was impossible so I just created an individual share for it and flipped a birdy at the deployer as it ran.
    The fact remains, not only should the installer be double checking path length PRIOR TO STARTING TO CREATE THE DEPLOYMENT but the people actually making the installation packages should be doing it as well.
    I doubt it would take one of Autodesk's engineers more than 1-2 hours per product in the suite or several hours to add the path length check to the deployer; and yet it would save hundreds (if not thousands or tens of thousands) of hours of their customer's time dealing with these issues.
    But why do that when you can just have a moderator blame the customer everytime the issue crops up on the forums.
    TravisNave
    08-09-2012 01:10 PM in reply to: MatthiasFostel
    I don't see any moderators saying the customer is wrong in this thread except for the OP stating the work-around for the known issue.  Anyway, I doubt any customer has spent thousands to tens-of-thousands of hours trying to figure out that a short path share would resolve the issue.  It took me 15 seconds to write this.  And I've never experienced this issue because I have always adhered to the \\servername\share convention.
    Travis Nave
    Active Member
    08-09-2012 01:16 PM in reply to: TravisNave
    The fact of the matter is Autodesk has known about this issue for several releases and refuses to do anything about it.  The CUSTOMER is being inconvenienced by it.  Fix the thing AutoDesk.
    Edited by
    Discussion_Admin
    TravisNave
    08-09-2012 01:22 PM in reply to: ktaylor
    :smileylol:
    Travis Nave
    Active Member
    GrantCollins
    08-09-2012 01:26 PM in reply to: TravisNave
    Thank U, that's exactly the point. I've done a bit of development myself and there is no reason that anyone would need filenames 70 - 90 characters long. They know this is an issue so for well now since 2009 for sure from my personal experience. And of course if doesn't error out until it reaches that file, like give me a break, do a check sum on the file path names before actually installing or even simpler yet shorten the filenames. I spent way too many hours have to rebuild packages because Autodesk shear laziness. This maybe would have been acceptable for a version, I get that programmers mess up but 5 years in a row.
    Thanks, Grant
    Edited by
    Discussion_Admin
    Distinguished Contributor
    08-09-2012 01:30 PM in reply to: TravisNave
    You are not helping any of us and you are not contributing anything. Some of us follow this to see Autodesks responce to this, no one cares about yours.
    Discussion_Admin
    Active Member
    GrantCollins
    08-09-2012 01:39 PM in reply to: spm5
     If Autodesk fixed there product than I would have anything to say about it, now would I. And after the hours I had to spend to fix my packages, I am going to complain a little. Trust me I have already made many feedbacks about it.
    Thanks, Grant
    Edited by
    Discussion_Admin
    TravisNave
    08-09-2012 01:55 PM in reply to: spm5
      Autodesk was the one that originally created this post as a response to this known support issue.  I am simply supporting the position that this is easily avoidable by following their recommendation.  I apologize if my support for the work-around was taken out of context.  I agree that steps should be taken to prevent this in the future, but the simple fact remains that this is the fix for now.  Furthermore, this is a peer to peer forum.  I recommend that you fill out a customer support request in recommending that this be resolved in a future release.
    Edited by
    Discussion_Admin
    Travis Nave
    Product Support
    08-20-2012 01:14 PM in reply to: TravisNave
    Autodesk is working on a plan to resolve this issue internally.  i.e. make paths a short a possible.   I have posted a workaround based on this forum post here:
    http://upandready.typepad.com/up_and_ready/2012/08/defeating-the-256-character-limit-when-creating-a...
    This post refers to an issue with 3DS Max Design in a Suite:
    http://upandready.typepad.com/up_and_ready/2012/04/autodesk-suites-2013-deployment-path-can-easily-e...
    This is a hot topic that should be resolved in a future release.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
