Seems like adskflex.exe is not running.
Did you install the NLM files from the 2007 CD? adskflex.exe, lmgrd.exe,
lmtools.exe, lmutil.exe
Did you get a new license file for the AutoCAD 2007 licenses?
Start lmtools.exe on the license server and tab Config Services should show
where the debug log file is.
Best Regards, Jimmy Bergmark
Owner/Developer - JTB World - Software development and Consulting
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Batch script and purge) -
http://www.jtbworld.com/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2006 and 2007
http://www.jtbworld.com/autocad2006.htm
http://www.jtbworld.com/autocad2007.htm
wrote in message news:5250424@discussion.autodesk.com...
New installation of ACAD 2007 network version. Installed license manager on
server. Deployed image for workstations and installed it on one. Start ACAD
and get message: A valid license could not be obtained by the network
license manager.... Error [1.5.-97]
* Rereading licenses shows only our ArcGIS license
* Performed status inquiry: Only see the ArcGIS license - Network ArcGIS
works properly
* Performed diagnostics and the ACAD license is found but ACAD still won't
run - same error.
What's the problem and how is it resolved? Also, where do the log/debug
files live?
JClay
