To use both licences you must combine your two licence file.
See
http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=3785782&linkID=2475323
Best regards
Franck Hervet
www.aricad.fr
a écrit dans le message de
news:5185865@discussion.autodesk.com...
Trying to install ADT 07 and Civil3d 07.
we have both licences (network) and are only able to use one program at a
time. The second always returns "A valid license could not be obtained by
the network license manager. Try Again"
I checked the log files and this is what i see. I have no idea what to make
of it (no idea what anything in the log file means..)
ADT2007 Log>>
9:07:33 (lmgrd) pid 7772
9:07:33 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:07:33 (lmgrd) Done rereading
9:07:33 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on Adistj
(IBM PC) (5/25/2006)
9:07:33 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or
Macrovision Corporation. All Rights Reserved.
9:07:33 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:07:33 (lmgrd) World Wide Web: http://www.macrovision.com
9:07:33 (lmgrd) License file(s): C:\Program Files\Autodesk Network License
Manager\License\ARCHDESK2007Adistj.lic
9:07:33 (lmgrd) lmgrd tcp-port 27000
9:07:33 (lmgrd) Starting vendor daemons ...
9:07:33 (lmgrd) Starting vendor daemon at port 2080
9:07:33 (lmgrd) Using vendor daemon port 2080 specified in license file
9:07:33 (lmgrd) Started adskflex (pid 7276)
9:07:33 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:07:33 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:07:33 (lmgrd) adskflex using TCP-port 2080
9:33:35 (adskflex) TCP_NODELAY NOT enabled
9:43:35 (adskflex) OUT: "51500ARCHDESK_2007_0F" RBaker@RBaker-PC
9:44:59 (adskflex) IN: "51500ARCHDESK_2007_0F" RBaker@RBaker-PC
9:54:24 (adskflex) Rereading license file...
9:54:24 (lmgrd) Done rereading
9:54:24 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:54:24 (adskflex) Updating feature 51500ARCHDESK_2007_0F
9:54:24 (adskflex) Rereading options file...
9:54:24 (adskflex) ...Finished rereading
9:54:39 (adskflex) Rereading license file...
9:54:39 (lmgrd) Done rereading
9:54:39 (adskflex) Server started on Adistj for: 51500ARCHDESK_2007_0F
9:54:39 (adskflex) Updating feature 51500ARCHDESK_2007_0F
9:54:39 (adskflex) Rereading options file...
9:54:39 (adskflex) ...Finished rereading
9:56:19 (lmgrd) Forced shutdown requested
9:56:20 (lmgrd) SHUTDOWN request from administrator at node adistj
9:56:20 (lmgrd) lmgrd will now shut down all the vendor daemons
9:56:20 (lmgrd) Shutting down adskflex
9:56:20 (adskflex) daemon shutdown requested - shutting down
9:56:20 (lmgrd) Shut down FLEXnet adskflex license server system on machine
adistj
>>CIVIL 3D 2007 LOG>>
9:56:41 (lmgrd) pid 2192
9:56:41 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:56:41 (lmgrd) Done rereading
9:56:41 (lmgrd) FLEXnet Licensing (v10.8.0 build 18869) started on Adistj
9:56:41 (lmgrd) Copyright (c) 1988-2005 Macrovision Europe Ltd. and/or
9:56:41 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:56:41 (lmgrd) World Wide Web: http://www.macrovision.com
9:56:41 (lmgrd) License file(s): C:\Program Files\Autodesk Network License
Manager\License\CIV3D2007adistj.lic
9:56:41 (lmgrd) lmgrd tcp-port 27000
9:56:41 (lmgrd) Starting vendor daemons ...
9:56:41 (lmgrd) Starting vendor daemon at port 2080
9:56:41 (lmgrd) Using vendor daemon port 2080 specified in license file
9:56:41 (lmgrd) Started adskflex (pid 7948)
9:56:41 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:56:41 (adskflex) Server started on Adistj for: 52200CIV3D_2007_0F
9:56:41 (adskflex) PLIST
9:56:41 (lmgrd) adskflex using TCP-port 2080
9:57:08 (adskflex) TCP_NODELAY NOT enabled
9:57:09 (adskflex) OUT: "52200CIV3D_2007_0F" tsooley@TSooley-PC
