• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Member
    Lekaimadh
    Error 0xc0000142 Alias Automotive 2013
    1062 Views, 14 Replies
    04-17-2012 10:27 AM
    Im having an issue with getting Alias Automotive 2013 to work. It installed fine but when I tried to launch it I get the application was unable to start correctly 0xc0000142.  I tried to reinstall all the Visual C++ libraries 2005 2005 x64 2008 2010 but still same thing. I have Autocad 2013, Sketchbook Designer 2013 and Showcase 2013 and they run with no issues. I reinstalled windows and tried to install Alias Automotive again It worked fine for a few days, I installed a few other software Photoshop, illustrator and Adobe Acrobat pro. I read somewhere here that the Acrobat 3d function was intefering so I uninstalled Acrobat and tried to get Alias to work but still nothing. How can I fix this what exactly is the problem? what does the 0xc000142 error mean is there a missing file a problem with a .dll file? whats the deal?
    Please use plain text.
    Member
    Misharkex
    Re: Error 0xc0000142 Alias Automotive 2013
    04-26-2012 08:44 AM in reply to: Lekaimadh
    Try to open in from bin folder
    New Member
    04-26-2012 03:05 PM in reply to: Lekaimadh
    I have the same problem.
    New Member
    05-20-2012 11:37 AM in reply to: Lekaimadh
    Same problem here too :robotfrustrated:
    Member
    05-20-2012 03:25 PM in reply to: Lekaimadh
    meme problème avec Alias design de la suite Product design 2013 sous Win 7 64
    alias 2012 marche sous win 7 64
    et
    alias 2013 marche sous Xp 64
    alors que faire pour Alias 2013 sous win 7
    Active Member
    Lekaimadh
    05-20-2012 08:50 PM in reply to: Lekaimadh
    the only thing that fixed it for me the first time was reinstalling the Windows I was runing Win 7 x64 bit, that worked fine for a few days, then I installed a bunch of other programs, Like the Adobe Softares, 3D max, Autocad, Showcase then alias stoped working again and was getting the same error. People can try reinstalling the windows that the only thing that can do anything. But Alias 2012 works fine even after Alias 2013 failed, whatever Autodesk did for the new version they messed up somewhere. Hope we have a solution real soon. Sketchbook Designer 2013 which came with Alias 2013 works fine
    Member
    05-31-2012 10:35 AM in reply to: Lekaimadh
    from my reseller
    Values are stored in…
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
    NT\CurrentVersion \Windows
    change the LoadAppInit_DLLs value to 0 for now
    it is now working
    06-02-2012 08:40 AM in reply to: JEANMICHELONOFRI5843
    It works !!!!! the funny thing is that I reported that error since the beta, and never get any answear from the developers
    Active Member
    Lekaimadh
    06-02-2012 10:54 AM in reply to: Lekaimadh
    Does it affect any other program because Im running a bunch of other Autodesk Softwer, AutoCad, Showcase, 3d max, Sketchbook designer and bunch of other cad programs Rhino and Solidworks. What exactly does changing the value of the registry key of Windoes NT to 0 do? Does this regstry key belong to the Adobe Alias or is part of Windoes?
    New Member
    06-02-2012 11:20 AM in reply to: Lekaimadh
    I had the same problem, change the old Kaspersky Internet Security 2010, with recent versions could not run alias 2013.
    Sorry for my poor english!
