• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Error 0xc000007b while starting AutoCad 2013
    9934 Views, 43 Replies
    09-19-2012 08:16 AM
    Hi, recently i downloaded the trial version of autocad2013 from the offical website.
    but after a successful install, i cant even start my autocad2013
    It shows an error 0xc000007b.
    acad.exe
    "The application was unable to start correctly (0xc000007b). Click OK to close the application."
    I am using Windows7 Ultimate 64bit verson.
    I did a little search on the net, most of the solution is install Microsoft Visual C++ 2010(x86 and x64) redistributable package and reinstall directx 9 but neither works
    Please help!!!
    Thanks in advance!
    Please use plain text.
    Product Support
    emily.xu
    Re: Error 0xc000007b while starting AutoCad 2013
    09-20-2012 01:45 AM in reply to: charles1017
    Check if this is your probelm:
    http://upandready.typepad.com/up_and_ready/2012/08/revit-2013-crashes-when-devicelock-program-is-ins...
    Or, please try to start autocad under diagnostic mode, see if you can run autocad:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6453117&linkID=9240617
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Emily Xu
    AutodeskCare | Product Support
    Autodesk, Inc.
    09-20-2012 06:18 AM in reply to: charles1017
    I didnt install devicelock program so i dont think this first link helped me
    and the second link "Starting AutoCAD® in Windows® diagnostic mode", i still get a 0xc000007b error
    in additon, some of the autocad product cant start too, for example the AdSync.exe which will be automactically start when windows starts
    think they share the same problem
    thanks,
    charles
    Product Support
    emily.xu
    09-20-2012 08:33 PM in reply to: charles1017
    Thank you very much for your update, for you got the same error under diagnostic mode starting, so it will maybe relate to your system, hardware or winodows componets,even the autocad installation, I would give you some suggestions to try:
    1  Try to update your graphic card diver
    2  Update your Operation system and install the latest update.
    3  Try to uninstall .net framwork 4.0, and reinstall it from your installation media: \3rdParty\NET\4\wcu\dotNetFramework
    4  If above not solve your problem, try to uninstall your autocad and reinstall. Please note to close your anti-virus ans firewall, since they will affect your installation file to registered and slow down the performance.
    Emily Xu
    Autodesk, Inc.
    09-21-2012 04:38 AM in reply to: charles1017
    do as you said, but still no luck
    after uninstallation of .Net framework 4 and a reboot, the program still show 0xc00007b error
    is this something do with embedded .net framwork in windows 7?
    thanks!
    Product Support
    emily.xu
    09-24-2012 12:37 AM in reply to: charles1017
    How about running Autocad by right-click shorcut and select Run as administrator?
    Emily Xu
    Autodesk, Inc.
    09-24-2012 04:33 AM in reply to: charles1017
    same, 0xc000007b
    Product Support
    emily.xu
    09-26-2012 08:44 PM in reply to: charles1017
    No better suggestion but remove all and try to reinstall:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    Emily Xu
    Autodesk, Inc.
    09-27-2012 06:22 AM in reply to: charles1017
    no luck.... 0xc000007b.......... :smileyfrustrated:
    Product Support
    emily.xu
    09-27-2012 06:37 PM in reply to: charles1017
    So sorry that your problem not solved, as I search our websit and internet, seems we tried most of the possible solutions.
    We tried to uninstall .net framework 4.0 and reinstall, didn't work, but I found this solution:
    http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except..., would suggest you to uninstall all versions of .net framework, and install the latest version from the AutoCAD 2013 installation media or microsoft website.
    Hope that helps!
    Emily Xu
    Autodesk, Inc.
