Installation & Licensing
charles1017
Message 1 of 57 (25,820 Views)
Error 0xc000007b while starting AutoCad 2013
25820 Views, 56 Replies
09-19-2012 08:16 AM
Hi, recently i downloaded the trial version of autocad2013 from the offical website.
but after a successful install, i cant even start my autocad2013
It shows an error 0xc000007b.
acad.exe
"The application was unable to start correctly (0xc000007b). Click OK to close the application."
I am using Windows7 Ultimate 64bit verson.
I did a little search on the net, most of the solution is install Microsoft Visual C++ 2010(x86 and x64) redistributable package and reinstall directx 9 but neither works
Please help!!!
Thanks in advance!
Product Support
emily.xu
Message 2 of 57 (25,800 Views)
Re: Error 0xc000007b while starting AutoCad 2013
09-20-2012 01:45 AM in reply to: charles1017
Check if this is your probelm:
http://upandready.typepad.com/up_and_ready/2012/08/revit-2013-crashes-when-devicelock-program-is-ins...
Or, please try to start autocad under diagnostic mode, see if you can run autocad:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6453117&linkID=9240617
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Emily Xu
charles1017
Message 3 of 57 (25,789 Views)
09-20-2012 06:18 AM in reply to: charles1017
I didnt install devicelock program so i dont think this first link helped me
and the second link "Starting AutoCAD® in Windows® diagnostic mode", i still get a 0xc000007b error
in additon, some of the autocad product cant start too, for example the AdSync.exe which will be automactically start when windows starts
think they share the same problem
thanks,
charles
Product Support
emily.xu
Message 4 of 57 (25,770 Views)
09-20-2012 08:33 PM in reply to: charles1017
Thank you very much for your update, for you got the same error under diagnostic mode starting, so it will maybe relate to your system, hardware or winodows componets,even the autocad installation, I would give you some suggestions to try:
1  Try to update your graphic card diver
2  Update your Operation system and install the latest update.
3  Try to uninstall .net framwork 4.0, and reinstall it from your installation media: \3rdParty\NET\4\wcu\dotNetFramework
4  If above not solve your problem, try to uninstall your autocad and reinstall. Please note to close your anti-virus ans firewall, since they will affect your installation file to registered and slow down the performance.
Emily Xu
charles1017
Message 5 of 57 (25,757 Views)
09-21-2012 04:38 AM in reply to: charles1017
do as you said, but still no luck
after uninstallation of .Net framework 4 and a reboot, the program still show 0xc00007b error
is this something do with embedded .net framwork in windows 7?
thanks!
Product Support
emily.xu
Message 6 of 57 (25,700 Views)
09-24-2012 12:37 AM in reply to: charles1017
How about running Autocad by right-click shorcut and select Run as administrator?
Emily Xu
charles1017
Message 7 of 57 (25,689 Views)
09-24-2012 04:33 AM in reply to: charles1017
same, 0xc000007b
Product Support
emily.xu
Message 8 of 57 (25,594 Views)
09-26-2012 08:44 PM in reply to: charles1017
No better suggestion but remove all and try to reinstall:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Emily Xu
charles1017
Message 9 of 57 (25,576 Views)
09-27-2012 06:22 AM in reply to: charles1017
no luck.... 0xc000007b.......... :smileyfrustrated:
Product Support
emily.xu
Message 10 of 57 (25,564 Views)
09-27-2012 06:37 PM in reply to: charles1017
So sorry that your problem not solved, as I search our websit and internet, seems we tried most of the possible solutions.
We tried to uninstall .net framework 4.0 and reinstall, didn't work, but I found this solution:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except..., would suggest you to uninstall all versions of .net framework, and install the latest version from the AutoCAD 2013 installation media or microsoft website.
Hope that helps!
Emily Xu
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
