Installation & Licensing
Erro ao instalar Autodesk Inventor 2013 64bit.
2 REPLIES 2
angel_otto
387 Views, 2 Replies
Instalei tanto pelo download direto do site, como por arquivos que eu baixei na internet e nenhum funcionou. Pelo download direto o programa instala normalmente, mas na hora de abrir dá um erro e fecha. Pelo instalador que baixei na internet ele para em um dos passos da instalação.
Gostaria de saber se é só comigo esse erro.
2 REPLIES 2
TravisNave
in reply to: angel_otto
Por favor, forneça uma captura de tela do erro. Obrigado.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dembkod
angel_otto ,
Hello. First, make sure you meet the system requirements:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15402497&linkID=9242018
Next, make sure you have a clean download. If you need a download, grab one from here:
  1. Go to http://www.autodesk.com
  2. At the bottom of the page, beneath "Help and Support" click "Customer Service"
  3. Click the "Ask" button for the "Virtual Agent"
  4. Once the Virtual Agent opens, click "Downloading and Installation"
  5. Click "Software Download links"
  6. Click "I need to redownload my product"
  7. Select the appropriate product and download
Then, log with an Administrator and turn off Antivirus and Windows UAC and install.
Then install any available product updates:
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019
After this, try to start the program. If you error, update your graphics card driver and retest.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
