Installation & Licensing
Erro ao abrir Inventor 2013 64bit.
1 REPLY 1
268 Views, 1 Reply
This error has occoured anytime I try to open the Inventor 2013 64bit.
1 REPLY 1
TravisNave
Inventor 2013 is NOT supported on Windows 8.  You might be able to set it to run in Windows 7 compatibility mode.  Make sure you have SP2 installed plus Update 1 for SP2 installed.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section16
Then make sure you have updated your video card to the latest WHQL certified driver.
Good Luck!
Autodesk Forums:
Administrator Productivity
