Installation & Licensing
Member
bmateriale
Message 1 of 6 (328 Views)
Enter Product Request Code - help trying to get it.
328 Views, 5 Replies
02-14-2013 10:01 PM
Is the product code the same a product request code?  if it is , when I input the number it gives me an error of:
"Please enter request code to activate your product
The request code you entered is not valid. Try again (Error 3)
The request code is generated by the product when you register/activate your product. To access the request code, start the product. On the Registration-Activation page, click Activate. The request code is displayed at the top of the page".
I'm looking fo the activation page on the flash drive that was sent to me, I see a bunch files , do not see the activation page?
What file do I open?
THere are many files.
I purchased the autodesk design suite ultimate. I just want AutoCAD.
Please advise on what I am suppose to do. I have a project  coming up next week. Need to start working on AutoCAD
Thanks.
Customer Service
joane.bonghanoy
Message 2 of 6 (326 Views)
Re: Enter Product Request Code - help trying to get it.
02-14-2013 10:23 PM in reply to: bmateriale
Hi bmateriale,
Request Code is a 32 digit alpha numeric code. You can generate one via this link
Joane Bonghanoy
Member
bmateriale
Message 3 of 6 (319 Views)
02-14-2013 10:35 PM in reply to: joane.bonghanoy
thank you but i am very confused. Do I get the request code when I put in the flash drive on my laptop?  I opened up the flash drive that was sent from AutoDesk  all I see  is a bunch of files.. Not Activation file?  I receive a product code & serial number from Autodesk
Customer Service
joane.bonghanoy
Message 4 of 6 (307 Views)
02-14-2013 11:26 PM in reply to: bmateriale
Hi bmateriale,
By any chance, have you already installed the software to your machine? If you haven't done so, you should be seeing the .exe file in the USB for installation.
Once installed, follow the steps on the link I gave previously to generate the Request Code.
Joane Bonghanoy
Member
bmateriale
Message 5 of 6 (293 Views)
02-15-2013 03:30 AM in reply to: joane.bonghanoy
Good morning,
I doubtI i installed.  Files I see is:
ADSULT
CER
Content
en-us
EULA
MSI
NLSDL
Set
Setup Res
x64
x86
Please help me.
philip.s
Message 6 of 6 (276 Views)
02-15-2013 09:31 AM in reply to: bmateriale
Hi Betty!
The installer will initiate when you open the Setup.exe located on your flash drive.
With that being said, I would assume that you already have the software installed, seeing as how this would of had to have happened in order for the afore mentioned activation process to happen. The activation page / file is not located on the flash drive, but occurs as a result of the installation / opening the program.
When you click on your start / windows button -> All Programs, do you  an Autodesk folder with the Design Suite in it?
Philip Schmelzer
You are not logged in.
Announcements
Need installation help?
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
