• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    ufgm2
    Email with hotfix for inventor has no password.
    3116 Views, 7 Replies
    06-29-2011 09:46 AM
    I have just downloaded the student version of autodesk inventor and have run into the hotfix issue; I am using windows vista home premium 32 bit. I followed the procedure of going to http://support.microsoft.com/kb/971138 and chose the first option (x86) and then opened the email that followed, however, the email did not contain a password at all:
    Password:
    Password changes on:
    Next password:
    Elsewhere there was a note that states "NOTE If the password does not exist or the password is blank in this mail, then the fix can be extracted without any password.". However, when I follow the link to the hotfix it takes me to a dark screen with a popup stating "The server hotfixv4.microsoft.com:80 requires a username and password".
    Now, hopefully you can see my issue. No username or password is given in the email but it won’t let me get to the hotfix without one.
    If anyone has got any ideas I would be so happy!
    Thanks in advance
    Steve
    ***Guru
    TravisNave
    Re: Email with hotfix for inventor has no password.
    06-29-2011 11:04 AM in reply to: ufgm2
    Here is the extracted file.  Enjoy!
    Help Improve the Autodesk Discussion Groups
    If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Product Support
    06-29-2011 11:10 AM in reply to: TravisNave
    This is what I got in the email from Microsoft:
    KB Article Number(s): 971138
    Language: All (Global)
    Platform: x64
    Location: (http://hotfixv4.microsoft.com/Windows%20Vista/sp3/Fix261357/6000/free/381496_intl_x64_zip.exe)
    Password: dgB9F9p$Wq
    Password Changes On:
    Next Password: q)Dc3sFr
    I would also request the it again if necessary.  Thanks Travis for extracting it for the end user.
    David Lau
    Product Support | Up and Ready Blog | If my reply was helpful, please Kudo or Accept as Solution. :smileywink:
    My 5 Top Issues in the Discussion Groups
    1402 Error [Uninstall] | Faro doesn't install | adlmPITSetProductInformation Errors | Empty Tool bar in AutoCAD Mac | Win 7 Registry Limit
    Member
    dueler96
    10-26-2011 05:10 PM in reply to: ufgm2
    Hi guys, I was able to install and extract the hotfix. But when I run the fix it says "Not applicable to your system" I have the Vista SP2 so I'm not sure whats wrong...... Any help?
    Product Support
    10-26-2011 07:19 PM in reply to: dueler96
    Can you create a new post? It might be a different issue.
    David Lau
    New Member
    bleierjake
    02-07-2012 02:42 PM in reply to: TravisNave
    The update does not apply to your system is what i get when i try this, what do i do? thank you
    bleierjake@yahoo.com
    **Master
    02-07-2012 02:43 PM in reply to: bleierjake
    have you contacted microsoft on the problem?
    New Member
    03-25-2012 10:52 AM in reply to: ufgm2
    i have about the same problem but i have a 64bit can someone that has the hotfix file help me. I downloaded hotfix but it is a file called 381496_intl_x64_zip can someone please help get the hotfix file i need inventor for a class and i can't use it till i have this stupid file
