• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Ecotect Analysis Silent Installation
    219 Views, 3 Replies
    03-07-2012 03:29 PM
    How do I do a silent installation of Ecotect Analysis 2012 for a network license installation?
    There seems to be no documentation at all, although when I try the /silent switch, I get an error saying:
    ERROR: You have not entered a serial number.
    This can be found on the label of your original CD-ROM.
    Proceed using a limited trial license only ?
    So obviously there is support for a silent installation...
    Please use plain text.
    New Member
    Re: Ecotect Analysis Silent Installation
    03-27-2012 08:45 AM in reply to: j.l.hamilton
    I've the same problem. In our university lab I've to install about 30 different programs. Ecotec is the only program that makes problems. All other ones have a workaround, even programs of very small fabs.
    TravisNave
    03-27-2012 09:13 AM in reply to: j.l.hamilton
    Have you tried creating a network deployment with a silent install?
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    03-27-2012 01:20 PM in reply to: TravisNave
    I couldn't see any such option to create "a network deployment with a silent install" for Ecotect Analysis. The installer is not the same as the rest of the AutoDesk products, which automate all of this for me :smileysad:
