Brian,
That error is not an indication of a failed return. In fact, this error by
itself is not an indication of a functional problem.
If you want to make sure the license is being returned, run LMstat or use
the status button in LMtools. You will see something like the following if
a seat is borrowed:
Users of 46400INVBUN_9_0F: (Total of 2 licenses issued; Total of 1 license
in use)
"46400INVBUN_9_0F" v1.000, vendor: adskflex
floating license
myname WKS1 WKS1 (v1.000) (SRV-B/27000 102), start Wed 8/25 7:16
(linger: 146580)
Note the "linger" flag, you will only see this if the license is borrowed.
The above example is using an Inventor license but it works the same for all
borrowable products.
Jerry Milana,
Autodesk Consulting
"bstaples" wrote in message
news:7606526.1093437441963.JavaMail.jive@jiveforum1.autodesk.com...
> When a user returns a borrowed license early, it tells them it was
successful. In the log file however I get the following message:
> 9:41:40 (adskflex) Checkin failed feature "46700ARCHDESK_2005_0F":
username stationname stationname
> Why is it saying it failed in the log but the process seems to be working
fine?
> Brian
