Installation & Licensing
ERROR 1603 Instaling 3ds Entertainment Creation Suite 2013
3 REPLIES 3
468 Views, 3 Replies
Hi, every time I tried to install this software I get this message:
2012/11/26:23:32:07 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/26:23:32:07 Ralph RALPHAX Launch
2012/11/26:23:32:14 Ralph RALPHAX === Setup ended ===
2012/11/26:23:32:09 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/26:23:32:09 Ralph RALPHAX Launch
2012/11/26:23:32:14 Ralph RALPHAX PageOpen LaunchDialog
2012/11/26:23:32:49 Ralph RALPHAX PageOpen LicenseDialog
2012/11/26:23:32:51 Ralph RALPHAX PageOpen ProductInfoDialog
2012/11/26:23:34:11 Ralph RALPHAX PageOpen ProductSelectionDialog2
2012/11/26:23:34:48 Ralph RALPHAX PageOpen FullProgressDialog
2012/11/26:23:34:48 Ralph RALPHAX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): E:\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ralph\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/26:23:34:53 Ralph RALPHAX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=1603
I installed manually the vredist_x86_2005 and theres no problem, but still got this message when i tried to install the software,
Also, I deleted my temp files, execute the setup as adminsitrator, an yet no results.
Please help me!
3 REPLIES 3
Darin.Green
Copy the media onto the hard drive. After the copy, navigate to the setup.ini file and open it with notepad. Browse to the following section:
[VCREDIST2005SP1ATLX86]
PLATFORM=ALL
PRODUCT_NAME=Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86)
EXE_PATH=3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe
Modify the EXE_PATH value to the following:
EXE_PATH=ECHO
This workaround should bypass the MS Visual C++ 2005 installation and continue installing the remaining applications.
Let me know if this works.
If this information was helpful, please consider using the Accept Solution
in reply to: Darin.Green
Hi, thanks, I tried what you told me but unfortunately didnt work; I stil get this log.
2012/11/27:22:48:51 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/27:22:48:51 Ralph RALPHAX Launch
2012/11/27:22:48:57 Ralph RALPHAX === Setup ended ===
2012/11/27:22:48:53 Ralph RALPHAX === Setup started on RALPHAX by Ralph ===
2012/11/27:22:48:53 Ralph RALPHAX Launch
2012/11/27:22:48:57 Ralph RALPHAX PageOpen LaunchDialog
2012/11/27:22:48:58 Ralph RALPHAX PageOpen LicenseDialog
2012/11/27:22:49:01 Ralph RALPHAX PageOpen ProductInfoDialog
2012/11/27:22:50:20 Ralph RALPHAX PageOpen ProductSelectionDialog2
2012/11/27:22:50:29 Ralph RALPHAX PageOpen FullProgressDialog
2012/11/27:22:50:29 Ralph RALPHAX Installing Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86): C:\Users\Ralph\3DS\ECHO /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\Ralph\AppData\Local\Temp\vcredist_x86_2005.log"" "
2012/11/27:22:50:29 Ralph RALPHAX Install Microsoft Visual C++ 2005 SP1 Redistributable ATL Security Update (x86) Failed Installation aborted, Result=2
Darin.Green
Ralph,
Attached the error log file and ini file to this thread or via private message.
Administrator Productivity
