This is a question about downloading the install files, NOT installing the software or modelling an entire city.
In attempting to download Autodesk Education Master Suite English 2013 Win 32/64 Download Manager reports "Not enough disk space." The page claims that the download is 42.1 GB and I have 136GB free so why does the error message claim that I need an additional 101 GB on that drive?
The deployment gets created on a different share with final installation to other machines so the disk space for actual installation should not be a problem once I actually get the thing actually downloaded.
Solved by Albert_Rius. Go to Solution.
Hi,.
Please check next link for information about file size when using the download manager:
Notice that you need at least 3 times of the filesize, but this will change depending on the compression level of the packet.
If this is a problem, you can use another method to download (download from browser) that will create few compressed files on your harddisk.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
