• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    Active Member
    s.peters
    Download Error?
    1755 Views, 18 Replies
    05-02-2012 01:33 AM
    I'm trying to downlad Product Design Suite Premium English 2013 Win 64.
    The website says its about 14 Gb but the download is actually 32 Gb. Which is a little odd. The main problem is that it downloads for a few hours and then comes up with:
    "Error 0x250000ff"
    The download stops and then when i restart it, it starts from scratch again.
    Any ideas? Thanks in advance.
    Please use plain text.
    Customer Service
    joane.bonghanoy
    Re: Download Error?
    05-02-2012 02:02 AM in reply to: s.peters
    Hi s.peters,
    Can yon reply back with a screenshot of the error so we can look into it further.
    Joane Bonghanoy
    AutodeskHelp | Customer Care Representative
    TW | PI | YT | BLOG
    Active Member
    s.peters
    Re: Download Error?
    05-03-2012 03:40 AM in reply to: joane.bonghanoy
    Certainly, please see the attached picture, (during the abort and after).
    Immediately before the abort started a message popped up from the download manager and said somthing like "you have been signed out of your online account" or something similar (i can't remember exactly).
    Customer Service
    celine.manca
    Re: Download Error?
    05-03-2012 05:40 AM in reply to: s.peters
    Hi s.peters,
    Thank you for these screenshots.
    Could you please DM me your User ID for the subscription center? We'll need to check your account for this issue.
    In the meantime, do you have the possibility to use the browser download instead of the download manager?
    Celine Manca
    TW | PI | YT | BLOG
    TravisNave
    Re: Download Error?
    05-03-2012 07:22 AM in reply to: s.peters
    For more detailed information on this process, please see the following blog post tip here:
    http://upandready.typepad.com/up_and_ready/2011/08/downloading-software-browser-download-vs-download...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    Re: Download Error?
    04-25-2013 10:19 AM in reply to: s.peters
    Hi, I'm having some problems as well.
    I already downloaded 700+ mb of Maya and I rebooted my computer; when I resumed downloading,
    It doesn't download anymore.
    What it shows is the image I've attached here.
    This problem always happen to me. Whenever I pause and resume, it won't download anymore.
    I've already downloaded mudbox without encountering this problem (maybe) because I did not pause it.
    Thanks a lot for any help.
    Member
    Re: Download Error?
    05-16-2013 09:23 AM in reply to: s.peters
    Hello.
    I have same problem with Autodesk Maya 2014. After downloading 200mb it will show same error.
    I tried to download it via Browser download, but after i downloaded it and tried to extract it, it always stoped at 61,9mb. I tried to wait for 10min, but nothing happened. Can you help me?
    Thank you
    philip.s
    Re: Download Error?
    05-16-2013 10:15 AM in reply to: ewerlast28
    Hello Marek!
    Are you manually extracting it or simply running the .exe?  Have you tried using the Install Now option?
    Philip Schmelzer
    AutodeskHelp | Community Manager
    TW | PI | YT | BLOG
    Member
    Re: Download Error?
    05-16-2013 10:52 AM in reply to: philip.s
    With Browser downloading It will downlaod .exe . Just double click on it and extract to ... but it always stuck at 61,9mb.
    I tried it with downloader... but with donwloader same error 2x25000ff at +-200mb downloaded.
    philip.s
    Re: Download Error?
    05-16-2013 02:48 PM in reply to: ewerlast28
    Thanks for confirming. You mentioned that you're getting this error with the Download Now option, but what about Install Now?
    Philip Schmelzer
    TW | PI | YT | BLOG
