Installation & Licensing
New Member
Message 1 of 4 (1,840 Views)
Download Error for REVIT 2013
1840 Views, 3 Replies
11-17-2012 09:34 AM
I have been trying to download Revit 2013 for 64 bit Windows (I run Windows 7 64 bit) read through all the other download errors *to search for possible solutions* but i've not been able to download it.
Here are some of the logs that I've got:
1. This one is when i almost got it, where it states that Revit has been succesfully installed but there's a faroSDK error..
 === Setup started on USER by 0wner ===
2012/11/17:16:02:16 0wner USER Launch
2012/11/17:16:02:19 0wner USER Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/17:16:02:20 0wner USER PageOpen LaunchDialog
2012/11/17:16:06:11 0wner USER PageOpen LicenseDialog
2012/11/17:16:06:11 0wner USER PageOpen ProductInfoDialog
2012/11/17:16:06:11 0wner USER PageOpen ProductSelectionDialog2
2012/11/17:16:06:19 0wner USER PageOpen FullProgressDialog
2012/11/17:16:06:19 0wner USER Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\WI\Autodesk Revit 2013 /q /norestart /c:"install.exe /qn"
2012/11/17:16:06:19 0wner USER Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=2
2012/11/17:16:06:20 0wner USER Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/17:16:06:20 0wner USER Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/17:16:07:00 0wner USER Install DirectX® Runtime Succeeded
2012/11/17:16:07:00 0wner USER Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/17:16:07:00 0wner USER Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\0wner\AppData\Local\Temp\FaroSDK.log"
2012/11/17:16:07:07 0wner USER Install FaroSDK Succeeded
2012/11/17:16:07:10 0wner USER Download Play RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:17:56:23 0wner USER Download Complete RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:17:56:23 0wner USER Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\0wner\AppData\Local\Temp\_AI80E2.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:12:42 0wner USER Install Autodesk® Revit® 2013 Succeeded Reboot is required
2012/11/17:19:12:45 0wner USER Download Play RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:19:14:45 0wner USER Download Complete RVT2013_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/17:19:14:46 0wner USERY Installing Autodesk® Revit® 2013 Language Pack: TRANSFORMS="C:\Users\0wner\AppData\Local\Temp\_AI80E2.tmp\_laBDE1.tmp.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:14:48 0wner USER Install Autodesk® Revit® 2013 Language Pack Succeeded
2012/11/17:19:14:49 0wner USER Download Play CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CM2...
2012/11/17:19:21:13 0wner USER Download Complete CM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CM2...
2012/11/17:19:21:13 0wner USER Installing Autodesk Material Library 2013: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:21:20 0wner USER Install Autodesk Material Library 2013 Succeeded
2012/11/17:19:21:21 0wner USER Download Play CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:19:30:02 0wner USER Download Complete CMILB2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:19:30:02 0wner USER Installing Autodesk Material Library 2013 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:19:30:06 0wner USER Install Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/17:19:30:07 0wner USER Download Play CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:31:36 0wner USER Download Complete CMILL2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:31:36 0wner USER Installing Autodesk Material Library 2013 - Low Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/17:20:31:46 0wner USER Install Autodesk Material Library 2013 - Low Image Library Succeeded
2012/11/17:20:31:48 0wner USER Download Play CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:54:18 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:55:10 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:12 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:12 0wner USER Download Paused CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:56:52 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:20:58:54 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:02:17 0wner USER Download Error CMILM2013 <B>No Response from Server</B>Please retry or download again from the website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:07:49 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:18:29 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:21:39:49 0wner USER Download Error CMILM2013 <B>Network Error, cannot download</B>Check connections and try again. Would you like to retry now? http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:08:52 0wner USER Download User Resume CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Download Error CMILM2013 <B>File not found</B>Please Install Now again from the Autodesk website. http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Download Aborted CMILM2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/CMI...
2012/11/17:22:25:19 0wner USER Install Autodesk Material Library 2013 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2012/11/17:22:25:20 0wner USER Rollback Autodesk Material Library 2013 - Low Image Library Succeeded
2012/11/17:22:25:26 0wner USER Rollback Autodesk Material Library 2013 - Base Image Library Succeeded
2012/11/17:22:25:34 0wner USER Rollback Autodesk Material Library 2013 Succeeded
2012/11/17:22:25:36 0wner USER Rollback Autodesk® Revit® 2013 Language Pack Succeeded
2012/11/17:22:26:28 0wner USER Rollback Autodesk® Revit® 2013 Succeeded
2012/11/17:22:26:28 0wner USER Rollback FaroSDK Failed Failure is ignored, Result=1619
2012/11/17:22:26:28 0wner USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2012/11/17:22:26:28 0wner USER PageOpen InstallCompleteDialog
2012/11/17:22:30:25 0wner USER === Setup ended ===
and log 2:
2012/11/18:01:05:33 0wner USER Launch
2012/11/18:01:05:36 0wner USER Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/SET...
2012/11/18:01:05:36 0wner USER PageOpen LaunchDialog
2012/11/18:01:08:15 0wner USER PageOpen LicenseDialog
2012/11/18:01:08:15 0wner USER PageOpen ProductInfoDialog
2012/11/18:01:08:15 0wner USER PageOpen ProductSelectionDialog2
2012/11/18:01:13:53 0wner USER PageOpen FullProgressDialog
2012/11/18:01:13:54 0wner USER Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\WI\Autodesk Revit 2013 /q /norestart /c:"install.exe /qn"
2012/11/18:01:13:54 0wner USER Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=2
2012/11/18:01:13:55 0wner USER Download Skipped DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/DIR...
2012/11/18:01:13:55 0wner USER Installing DirectX® Runtime: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\DirectX\DXSETUP.exe /silent
2012/11/18:01:14:28 0wner USER Install DirectX® Runtime Succeeded
2012/11/18:01:14:29 0wner USER Download Skipped FaroSDK http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/Far...
2012/11/18:01:14:29 0wner USER Installing FaroSDK: C:\Autodesk\WI\Autodesk Revit 2013\3rdParty\FaroSDK\e889_faro_ls_sdk_4.8.2.25521_x86_setup.exe /VERYSILENT /NORESTART /LOG="C:\Users\0wner\AppData\Local\Temp\FaroSDK.log"
2012/11/18:01:14:33 0wner USER Install FaroSDK Succeeded
2012/11/18:01:14:34 0wner USER Download Skipped RVT2013 http://studentsdownload.autodesk.com/SWDLDDLM/2013/RVT/WI/{B3025DA1-3BA9-4315-AC55-664F5487ABA5}/RVT...
2012/11/18:01:14:34 0wner USER Installing Autodesk® Revit® 2013: TRANSFORMS="C:\Autodesk\WI\Autodesk Revit 2013\x64\en-us\RVT2013\RVT2013.mst;C:\Users\0wner\AppData\Local\Temp\_AI8853.tmp\x64\RVT2013\RVT2013-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2013" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/11/18:01:14:34 0wner USER Install Autodesk® Revit® 2013 Failed Installation aborted, Result=1618
2012/11/18:01:14:34 0wner USER Rollback FaroSDK Failed Failure is ignored, Result=1618
2012/11/18:01:14:34 0wner USER Rollback DirectX® Runtime Failed Failure is ignored, Result=1618
what did i do wrong? please help ! *thanks in advance*
Product Support
Message 2 of 4 (1,800 Views)
Re: Download Error for REVIT 2013
11-19-2012 01:31 PM in reply to: lala121
Please try a browser download if possible.
David Lau
New Member
Message 3 of 4 (1,568 Views)
01-03-2013 03:08 PM in reply to: lala121
I have the same issue. I tried the browser download and that did not work either. What can I do to fix this?
New Member
Message 4 of 4 (1,313 Views)
02-14-2013 02:15 PM in reply to: esroberts17
I have the same problem with Install Now, Browser and so on..it never complets the download!
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
