Dear All,
I am transfering Autocad LT from an old computer to a new one.
I removed the license from old PC, using the License Transfer Utility.
I just do not find how to download Autocad LT 2011 on the Autodesk web site, I have no media.
Would you please send me a link ?
Hi Cedric_B135,
Here are the download links for AutoCAD LT 2011. Please, note that these links are temporary and will expire in 72 hours:
Let me know if you need any further help:)
Is there anyway to re-up these links? I am in a similar situation and am in need of Autocad architecture 2011 and cant seem to find a legitmate, safe copy anywher on the web. Thanks in advance!
Hi Rabid,
Refer to the links below which were set to expire in 72 hours.
- AutoCAD Architecture 2011 - 32 bit
- AutoCAD Architecture 2011 - 64 bit
I have the same problem as the guys above me. Need to shift my Autocad Inventor 2011 to a different computer but cannot find the disc. Please send me a link I can use to download it.
Thank you very much but unfortunately I had my email notifications turned off and didnt know you had posted! Can you renew the links once more? (for 2011 architecture) Thanks again for your help.
Thanks Camilo,
I did not list my product properly which I think is causing me to have issues transferring the license.
The product I require is AutoCAD Inventor LT Suite 2011.
If this is what is likely to be giving me issues transferring the license please send me a new link, otherwise do you have any suggestions as to what the cause may be.
Thanks again.
Hello Sam and Bill,
AutoCAD Architecture 2011 and AutoCAD Inventor LT Suite 2011 (Inventor LT 2011 + AutoCAD LT 2011) software download links can be accessed directly through Matt, our online Virtual Assistant.
Matt can be found by clicking on the above link, or directly from any of the tabs on our Customer Service page by clicking on the ASK button following the “Get answers from our online Virtual Agent” text -> Download and Installation -> Software Download Links -> I need to redownload my product.
Hi Massimo!
You will most likely either need to modify or repair the installation to resolve the missing LTU issue.
1. On the Start menu (Windows), click Settings > Control Panel.
2. In Control Panel, double-click Add or Remove Programs (Windows 2000/XP) or Programs and Features (Windows Vista/Windows 7).
3. Select the AutoCAD LT 2013, and then click Change or Modify.
4. Click Add or Remove Features
5. Check the License Transfer Utility box if it isn't already and update.
6. Is it available? Start -> Programs -> Autodesk -> AutoCAD LT 2013 > License Transfer Utility
7. If not, click on Repair or Reinstall from the previous screen.
If that doesn't work, I'd recommend simply activating the product via the standard process. If for some reason you run into an activation limit reached error, please contact our License Assistance team, providing a request code in exchange for an activation code.
Here to help if additional clarification is needed!
I am in a similar situation and need of Autocad architecture 2011 to my new computer and cant seem to find a legitmate, safe copy anywher on the web. Can some one provide the link to down load Autocad Lt 2011.
Hi Zahid and welcome to the Discussion Forums!
If you would like to re-download a supported Autodesk product, you may do so directly through our Virtual Agent.
However, these are just download media links. You will need a valid Autodesk license to activate the products downloaded from that page.
I hope this helps! Please let us know if you have any other questions!
Thank you,
I am trying to transfer my AutoCAD LT 2011 from an old computer to a new one and need the 64 bit version on the new computer. I didn't realize the version I had downloaded when I order it wouldn't install on a 64 bit machine and have already removed the old computer. Is it possible to get a link to download the 64 bit version of LT 2011. I've tried downloading it by looking up my order thru the store, but only get a PDF when I click the download button.
Any help is greatly appreciated since I am completely unable to do any work at the moment.
