Installation & Licensing
Distinguished Contributor
warrenandy
Message 1 of 8 (65 Views)
Do Suites contain all three versions just activated by SN?
65 Views, 7 Replies
05-07-2012 01:15 PM
We have Factory and Product Design Suits, all three versions (Standard, Premium and Ultimate). Can I install any version from any Key? Then just use the correct SN? It really doesn't matter to us because we use Network licenses so we install Ultimate on all machines then the LM deals out what users need. My question is if I grab a Standard and use the Ultimate SN will it install everything?
Andrew Warren
CAD & Data Management Specialist
Bridgestone Americas Tire Operations
andrew.warren@bellsouth.net
TravisNave
Message 2 of 8 (61 Views)
Re: Do Suites contain all three versions just activated by SN?
05-07-2012 02:38 PM in reply to: warrenandy
If it is indeed a network seat, install the ultimate and it will pull the licenses from the lower suites until a heftier license is needed.  However, it will not relinquish a license until it is closed and relaunched. You should be good to go.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
warrenandy
Message 3 of 8 (59 Views)
05-07-2012 03:03 PM in reply to: TravisNave
Thank you Travis, let me ask it a different way...
Is the physical media the same on the USB for Standard as it is for Ultimate?
Ie if I had standalone seats and I was to install PDS using the Ultimate SN but the Standard USB would I get the same results as I would using the Ultimate SN with the Ultimate USB? I ask more out of curiosity than necessity...
Andrew Warren
warrenandy
Message 4 of 8 (58 Views)
05-07-2012 03:08 PM in reply to: warrenandy
Just checked the Standard USB it is only 14GB Where the Ultimate is 24GB of data. So I would guess no is the answer if I was to try what I was suggesting.
I was thinking worse case if a user grabbed the wrong one. But looks like if they do they will have to reinstall if they did...
Andrew Warren
TravisNave
Message 5 of 8 (56 Views)
05-07-2012 03:37 PM in reply to: warrenandy
It's my understanding that the suites contain all the same products, they're just activated by the correct serial and product key. This is because you can't install all three at the same time so it's all handled by licensing only.
warrenandy
Message 6 of 8 (48 Views)
05-08-2012 06:45 AM in reply to: TravisNave
Nope the USB has fewer files on the Standard version than the Ultimate...
I just checked the Premium and it is the same as the Standard USB so maybe Ult has a few more things with it.
Andrew Warren
TravisNave
Message 7 of 8 (45 Views)
05-08-2012 07:08 AM in reply to: warrenandy
I'm sorry, I should have been more specific. Always install all of your suites with Ultimate and it will properly cascade.
warrenandy
Message 8 of 8 (44 Views)
05-08-2012 07:19 AM in reply to: TravisNave
I was more interested in the Physical USBs because I have e so many to do. I was thinking I could use all three if I had to. It is kind of moot because I am using Deployments but I was more curious if it was their if I needed it. I am also having problems creating a deployment and ADSK thinks I may have a bad key. That would have allowed me to check if all three where the same I could have just grabbed another and used it. Instead I had to order a new one and wait a couple days only o find out it is NOT the key...
Andrew Warren
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
