We have Factory and Product Design Suits, all three versions (Standard, Premium and Ultimate). Can I install any version from any Key? Then just use the correct SN? It really doesn't matter to us because we use Network licenses so we install Ultimate on all machines then the LM deals out what users need. My question is if I grab a Standard and use the Ultimate SN will it install everything?
If it is indeed a network seat, install the ultimate and it will pull the licenses from the lower suites until a heftier license is needed. However, it will not relinquish a license until it is closed and relaunched. You should be good to go.
Thank you Travis, let me ask it a different way...
Is the physical media the same on the USB for Standard as it is for Ultimate?
Ie if I had standalone seats and I was to install PDS using the Ultimate SN but the Standard USB would I get the same results as I would using the Ultimate SN with the Ultimate USB? I ask more out of curiosity than necessity...
Just checked the Standard USB it is only 14GB Where the Ultimate is 24GB of data. So I would guess no is the answer if I was to try what I was suggesting.
I was thinking worse case if a user grabbed the wrong one. But looks like if they do they will have to reinstall if they did...
Nope the USB has fewer files on the Standard version than the Ultimate...
I just checked the Premium and it is the same as the Standard USB so maybe Ult has a few more things with it.
I was more interested in the Physical USBs because I have e so many to do. I was thinking I could use all three if I had to. It is kind of moot because I am using Deployments but I was more curious if it was their if I needed it. I am also having problems creating a deployment and ADSK thinks I may have a bad key. That would have allowed me to check if all three where the same I could have just grabbed another and used it. Instead I had to order a new one and wait a couple days only o find out it is NOT the key...
