Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Distrubite d Network License File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi, I am trying to clarify where we should save our license file received from our cad supplier. We currently have 8 licenses of Building Design Suite Premium and 1 copy of Building Design Suite Ultimate and 1 copy of Infrastructure Design Suite Ultimate and the supplied file has all of the details added.
the file has been saved onto our server into the same folder ans the BDS Premium setup files. Is this the correct location or should it be saved some where else. Also we seem to be having trouble in not being able to access all of the available licenses. ie. only 4 people using a license and a 5th person not being able to get a license when there should be 6 spare.
Andy suggestions.
Re: Distrubite d Network License File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Typically, your license file should be placed in a license folder within your Autodesk Network License Manager (or Flexnet) folder. You need to configure your LMTOOLS to run as a service to properly serve and diagnose the licensing. If your multiple product licenses were not created on the same date, then they will not properly combine or cascade. Make sure that you have set up your license manager properly.
For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
http://forums.autodesk.com/t5/Installation-Licensi
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Distrubite d Network License File
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for the info. will give this a try and hopefully it should work
