• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Booth, David
    Directory and Share Permissions
    89 Views, 7 Replies
    05-17-2000 04:59 AM
    Greetings,
    Can anyone suggest a directory and share permission profile that I could
    copy or reference to setup a networked version of AutoCAD Map 2000 on an NT
    server?
    David Booth
    CAD Manager
    RCN Westwood
    Please use plain text.
    *Nehls, Kevin
    Re: Directory and Share Permissions
    05-17-2000 08:40 AM in reply to: *Booth, David
    Simply put, Read-only. Then save a copy of your "standard" profile to their
    local drive. Also, if you would like the user to be able to customize
    toolbars then create an empty MNU file with a menu group name of your
    choosing, then load that MNU to create the MNS, MNR, and MNC files. Now
    delete the MNU file to keep the user from accidentally reloading an blowing
    away any of their toolbar changes. Now when they go to create custom
    toolbars they can create them in that "Personal" menugroup, they will
    receive a few messages (depending on how many other menus are loaded stating
    that they can't write to the MNS files, but it will be able to write to the
    "Personal" (Local) MNS file. I would also move the MNU files on the server
    to a location that the users don't have access to. This would eliminate the
    "desire" for the users to edit the "standard" MNU files when they can edit
    their local MNS files.
    On my network, I also have the Acad.lsp and Acaddoc.lsp files compiled to
    .fas files and the lsp files move to another location. I have the
    Acaddoc.lsp file loading a "MyAcad.lsp" file that the user can have saved to
    their local drive to change any variables or load any other routines that
    they want. BTW, the loading of the "MyAcad.lsp" file is done in the
    S::smileyfrustrated:TARTUP section.
    Hope this helps.
    Kevin Nehls
    remove -ns- for direct reply
    David Booth wrote in message ...
    >Greetings,
    >server?
    >Thanks,
    >David Booth
    >CAD Manager
    >RCN Westwood
    *Booth, David
    Re:
    05-18-2000 03:06 AM in reply to: *Booth, David
    Kevin,
    Thanks for the reply. Is it really true then that there's no files in the
    acad executable or supporting directory that users need write or change
    privledges to? And how about the ADLM license server directory?
    Kevin Nehls wrote in message
    news:ef08912.0@WebX.SaUCah8kaAW...
    their
    blowing
    stating
    the
    server
    the
    to
    > Hope this helps.
    > Kevin Nehls
    > >Greetings,
    NT
    > >server?
    > >Thanks,
    > >David Booth
    > >CAD Manager
    > >RCN Westwood
    *B, Jimmy
    Re:
    05-18-2000 05:06 AM in reply to: *Booth, David
    I think acad2000.cfg has to be set to rw.
    Best regards: Jimmy B
    CAD coordinator at Emtunga International AB
    http://hem.fyristorg.com/cadman/
    www.emtunga.com
    David Booth skrev i diskussionsgruppsmeddelandet:ef08912.1@WebX.SaUCah8kaAW...
    > Kevin,
    > their
    > blowing
    > stating
    > the
    > server
    > the
    > to
    > > Hope this helps.
    > > Kevin Nehls
    > > >Greetings,
    > NT
    > > >server?
    > > >Thanks,
    > > >David Booth
    > > >CAD Manager
    > > >RCN Westwood
    *Nehls, Kevin
    Re:
    05-18-2000 08:17 AM in reply to: *Booth, David
    That's true, but if you are doing a network deployment with A2K (maybe R14
    as well) during the install on the client the CFG file is saved to the
    directory that you specified to be created (or used) on the client when you
    setup the image directory.
    In my so far limited testing there are no program files that the user needs
    to have write access to. When I set my directories to read-only the only
    messages that popped up stated anything about not being able to write to a
    file was when I modified toolbars. The messages stated that the changes
    would not be kept since they could not write to the MNS files. This can be
    fixed by creating the "Personal" MNS file on the local drive as I stated in
    my first post.
    Also, the users should not have ANY need to EVER access the AdLM server.
    This will eliminate the potential for them burying other clients so that
    they can get a license. They also don't even need to know where the
    directory is on the AdLM server. The ACADSERVER environment variable points
    to the AdLM server and the service that is running on the AdLM server takes
    care of the requests for licenses. When I setup my AdLM server I did not
    create a share to that directory and it installed to the C drive of the
    server, which is hidden (by default) and inaccessible to the clients. I
    have had no problems getting licenses.
    Kevin Nehls
    Jimmy B wrote in message ...
    >www.emtunga.com
    *milana, jerry
    Re:
    05-18-2000 09:31 AM in reply to: *Booth, David
    Just to clarify a point Kevin is making. You do not have to share the AdLM
    directory but the adlm\log and adlm\key directories and their contents must
    NOT be write protected, AdLM will fail if they are.
    Jerry Milana,
    Autodesk Product Support
    "Kevin Nehls" wrote in message
    news:ef08912.3@WebX.SaUCah8kaAW...
    you
    needs
    be
    in
    > my first post.
    points
    takes
    > Kevin Nehls
    > >www.emtunga.com
    *Nehls, Kevin
    Re:
    05-18-2000 03:21 PM in reply to: *Booth, David
    So do those directories need change permission for the user account that is
    requesting a license, or for the Administrator account, or just for the
    system account (since it is just a service running on NT). Currently in my
    test environment I have AdLM installed on a test bed NT server that is using
    FAT instead of NTFS and I have just created a hidden share to where I have
    change permissions through.
    I have just ran a test in where I have changed the permission for the share
    that I go though to the AdLM directory to NO ACCESS, I was able to open up
    AutoCAD without a problem. Which account exactly needs to have the change
    permissions to that directory, the Administrator or the system account?
    Kevin Nehls
    jerry milana wrote in message ...
    >Jerry Milana,
    *milana, jerry
    Re:
    05-18-2000 04:16 PM in reply to: *Booth, David
    Kevin,
    What we recommend is that the permissions on the file level be wide open on
    these directories and files. If you choose to share these files for remote
    administration, restrict access at the share level.
    Jerry
    news:ef08912.5@WebX.SaUCah8kaAW...
    is
    my
    using
    share
    > Thanks
    > Kevin Nehls
    AdLM
    must
    > >Jerry Milana,
