Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
DirectX Runtime Failed Failure is ignored, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created a deployment on a VM running Server 2008 R2. When I run the installer from the workstation, during the installation just disappears. No errors or notifications.
When I check the deployment log I see the following
irectX Runtime Failed Failure is ignored, Result=1619.
Here is the entire log.
2012/8/7:13:02:55 Administrator Z400-PC === Setup started on Z400-PC by Administrator === 2012/8/7:13:02:55 Administrator Z400-PC Launch 2012/8/7:13:03:18 Administrator Z400-PC Inventorui
2012/8/7:13:03:21 Administrator Z400-PC Install A
2012/8/7:13:05:38 Administrator Z400-PC Install F
2012/8/7:13:05:58 Administrator Z400-PC Install A
2012/8/7:13:06:16 Administrator Z400-PC Install A
2012/8/7:13:06:29 Administrator Z400-PC Install A
2012/8/7:13:06:34 Administrator Z400-PC Install A
2012/8/7:13:06:36 Administrator Z400-PC Install A
2012/8/7:13:13:04 eric.hoffman GLSDAPP01 === Setup started on GLSDAPP01 by eric.hoffman === 2012/8/7:13:13:04 eric.hoffman GLSDAPP01 Launch 2012/8/7:13:13:20 eric.hoffman GLSDAPP01 === Setup ended ===
2012/8/7:13:17:24 Administrator Z400-PC === Setup started on Z400-PC by Administrator === 2012/8/7:13:17:24 Administrator Z400-PC Launch 2012/8/7:13:17:57 Administrator Z400-PC === Setup ended ===
Re: DirectX Runtime Failed Failure is ignored, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Just had a thought. Can I browse to the share/installer via UNC, or must I browse the path directly?
I seem to recall running into a similiar problem a year or two ago and had to modify my deployment.
Currently I'm setup like this.
\\server\share\autodesk2012deploy
Should I browse like so?
\\server\e$\autodesk\autodesk2012deploy$
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD® 2013 Failed Installation aborted, Result=1603
Actually looks good up until this point. You probably need to look at the install log on the client to see where the 2013 is failing. Could be permissions or some other inconsistency.
You could try installing straight from media and seeing if you get the same problem. If not, it is likely an issue in your deployment. Typically, I do not recommend using administrative $ shares in a UNC path, though technically it shouldn't matter.
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: DirectX Runtime Failed Failure is ignored, Result=161 9
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Travis, where would one find the log on the client side?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There should have been one created in the user's %TEMP% folder location.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Installing locally seems fine, so I'll go ahead and rebuild my deployment on the server.
Any ideas of what went wrong? FYI - I just built two of these deployments for other sites (similiar hardware) and both ran fine. Biggest difference here is the server for deployment is a VM.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
It's hard telling. Make sure your shared folder has full read/write to the everyone user account and that the folder is set to an exception to anti-virus. I would recommend that you don't use an administrative $ share and when you make your deployment, do not make it a silent deploy. Just some of my own recommendations.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
What is the solution ? for this problem on Windows 7 - 64bits
Thank-you for your Help
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I'm having the same failure with Max 2013 on x64. In the Area they suggest running the download OR copying the DVDROM to the hard drive. Same failure for me trying both methods.
