• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Mhellstrom
    Design Review 2012 install problems
    151 Views, 2 Replies
    02-09-2012 03:39 AM
    Hello
    I got poblems with installing Design Review 2012. I managed to get 2011 to work, from there I can update to 2012. There is a small problem with this though. I need to to this on many computers in the future and I want to get an installation with both Design Review and TrueView to work so the installation progress will go faster and smoother.
    Ill attach a few pictures from the installation including the log file.
    Im installing from c:/temp/
    ***Guru
    TravisNave
    Re: Design Review 2012 install problems
    02-09-2012 07:36 AM in reply to: Mhellstrom
    You should uninstall Design Review 2011 before installing Design Review 2012.
    For more information on the Autodesk KB Support article concerning the clean uninstall of Autdoesk products, see this link:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
    My Top Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Administrator | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combining .LIC Files | Search Autodesk Discussion Groups
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    Mhellstrom
    02-09-2012 11:59 PM in reply to: TravisNave
    This didn't solve my problems.
    Were not able to disable all functions from my Antivirus, I'll try to install ADR 2012 on a clean computer later on if u dont have any other solution based on the log.
