Hi There,
We are looking to deploy Autodesk Inventor 2015 to a suite of computers (20 in total) - and possibly some high-end laptops too.
I was just wondering if you have a guide available or if someone can point me in the right direction towards doing a mass-deployment?
I'm failing to see any pre-made MSI's/ADMX templates etc - do I have to repackage your software in order to do a network deployment via group policy?
I'm surprised this isn't under the FAQ!
Part of the install options is to create a network deployment. This should be covered in the Installation Guide.
From what I found there wasn't much information on this at all.
Does it literally create the MSIs for you?
Can you point me in the direction of the manual you are referring to please?
Under this link you can find informations about the network deployment:
When you have created the deployment you can also modify for your special case. All is "readable" through a setup.ini file.
regards
Markus
