I've 2 seperate license for Autodesk Revit 2013 and now im trying to configure it to be deployed by network.
How do i make it so that the 2 licenses can be controlled from 1 nlm?
From the nlm side ive setup 2 processes to listen to the 2 license and have made a deployment package.
But from the deployment setup, the product info is for 1 of the license and thus not sure if it only check for that license. The network license is selected with Single License Server.
As the deployment package took me 4 hours to create, trial and error is not really an option.
Vincent Tan
Solved by TravisNave. Go to Solution.
You need to make sure that your licenses are both generated by Autodesk on the same date. At that point, you can simply combine the license files into one .LIC file (or ask Autodesk to do it for you) and create one service in LMTOOLS to run both licenses. Then your one deployment (using either serial - it doesn't matter which) will work and be able to check out either seat from the NLM.
