Installation & Licensing
Deployment of Revit Structure 2013
5 REPLIES 5
butzemann
466 Views, 5 Replies
Hello, I have to deploy several Autodesk products and currently I try to deploy the above mentioned program Revit Structure 2013. The logfile is attached. OS is XP SP 3 fully patched. I tried to install the DirectX version in the 3rdparty folder but there was no different. If I use the link for installation the installation is working. I rebuild this link in my deployment system but it failed. The deployment version was created on a windows 7 64-bit os.
Edited by
Discussion_Admin
5 REPLIES 5
david.lau
in reply to: butzemann
Can you try to re-create the deployment using Windows XP and then install it on XP?   Also, are you able to directly install the software on the target computer?
David Lau
butzemann
in reply to: david.lau
Thanks for your response. I re-created the deployment image on a windows xp virtual machine but the error during installing is the same.
Using the created shortcut in the admiimage folder for installation works. (runas)
butzemann
And now I installed it using a computer account instead of a service one and it works. And I still don't understand why.
david.lau
Strange indeed.  Just an FYI, Windows 7 x64 is a worthwhile upgrade if possible.  Here are some notes about 32 bit vs 64 bit:
http://upandready.typepad.com/up_and_ready/2011/09/general-systems-what-is-the-difference-between-32...
Some notes about Windows 8 is here:
http://upandready.typepad.com/up_and_ready/2012/11/the-joy-of-windows-8-and-anything-new.html
http://upandready.typepad.com/up_and_ready/2012/11/windows-8-support.html
David Lau
DannyHubbard
I don't see the log file attached so this is just an educated guess. Make sure your service or system account has full access to “C:\Documents and Settings\All Users\Application Data\Autodesk".
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Administrator Productivity
