Installation & Licensing
Active Member
butzemann
Message 1 of 6 (308 Views)
Deployment of Revit Structure 2013
308 Views, 5 Replies
11-22-2012 08:51 AM
Hello, I have to deploy several Autodesk products and currently I try to deploy the above mentioned program Revit Structure 2013. The logfile is attached. OS is XP SP 3 fully patched. I tried to install the DirectX version in the 3rdparty folder but there was no different. If I use the link for installation the installation is working. I rebuild this link in my deployment system but it failed. The deployment version was created on a windows 7 64-bit os.
Edited by
Discussion_Admin
Product Support
david.lau
Message 2 of 6 (285 Views)
Re: Deployment of Revit Structure 2013
11-23-2012 10:54 AM in reply to: butzemann
Can you try to re-create the deployment using Windows XP and then install it on XP?   Also, are you able to directly install the software on the target computer?
David Lau
Active Member
butzemann
Message 3 of 6 (227 Views)
11-27-2012 11:14 PM in reply to: david.lau
Thanks for your response. I re-created the deployment image on a windows xp virtual machine but the error during installing is the same.
Using the created shortcut in the admiimage folder for installation works. (runas)
Active Member
butzemann
Message 4 of 6 (219 Views)
11-28-2012 12:29 AM in reply to: david.lau
And now I installed it using a computer account instead of a service one and it works. And I still don't understand why.
Product Support
david.lau
Message 5 of 6 (210 Views)
11-28-2012 06:10 AM in reply to: butzemann
Strange indeed.  Just an FYI, Windows 7 x64 is a worthwhile upgrade if possible.  Here are some notes about 32 bit vs 64 bit:
http://upandready.typepad.com/up_and_ready/2011/09/general-systems-what-is-the-difference-between-32...
Some notes about Windows 8 is here:
http://upandready.typepad.com/up_and_ready/2012/11/the-joy-of-windows-8-and-anything-new.html
http://upandready.typepad.com/up_and_ready/2012/11/windows-8-support.html
David Lau
Employee
DannyHubbard
Message 6 of 6 (206 Views)
11-28-2012 07:00 AM in reply to: butzemann
I don't see the log file attached so this is just an educated guess. Make sure your service or system account has full access to “C:\Documents and Settings\All Users\Application Data\Autodesk".
Danny
Danny Hubbard
QA Analyst
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
