It's not possible out-of-the-box.
You can of course try to delete some of the files/folders manually and see
it it still works and it probably will.
Jimmy Bergmark
JTB World - Software development and consulting
Owner/Developer
http://www.jtbworld.com
http://jtbworld.blogspot.com
JTB World offers you software's, custom software development, consulting...
http://www.jtbworld.com/about.htm
JTB FlexReport (FLEXnet / FLEXlm license report tool) -
www.jtbworld.com/jtbflexreport
AutoCAD 2008
http://www.jtbworld.com/autocad2008.htm
"DAKare" wrote in message news:5821767@discussion.autodesk.com...
> When I make a deployment from Inventor dvd's (pro 2008), the size of the
> deployment folder is always the same, even if I just select to install
> mechanical. Is it possible to change this, make it smaller?
