I'm tring to install DWG Trueviewer 2012 in silent mode w/o reboot.
dotNetFx40_Full_x86.exe /q /norestart
Setup.exe /w /t /q setup.ini
Framework installs right and silent w/o reboot. But when installation of trueviewer starts it immediately reboot pc.
Is it possible to prevent it and install w/o any reboot?
Check out this post:
I forgot to say, it is Windows 7, not WinXP
And that topic about directX, not Framework.
And your colegue sad "if you can install directx with "dxsetup /silent" then restart the machine". My task is to install DWG TrueViewer without reboot as part of windows installation (using factory WIS)
I got another guru to help me out.
"This is a tricky one, we have to get the logs to find what forces the reboot."
"Another option is use msiexec /q / I trieview.msi after the pre-requisites so that it avoid setup.exe. It is possibly forcing the reboot.
