Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Deployment 32-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I created a 32-bit on this same machine (it is Win7 64-bit) for ACADE just fine. When I went to do a 32-bit Product Design suit 2012 it errors out? I get to the screen where you enter the name of the deployment and change it to 32-bit. As soon as I do it gives me the attached error. I can change it back to 64-bit and it works fine.
With that said I am currently having a issue gettting 2013 to create a deployment. ADSK support is working on that, I am not sure this is realted though...
CAD & Data Management Specialist
Bridgestone Americas Tire Operations
andrew.warren@bellsouth.net
Re: Deployment 32-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I did 2012 Factory Design Suite 32-bit and it worked fine. Just PDS giving me problems...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Do not use drive letters and this often causes problems. Your deployment pathing should use UNC paths (i.e. \\servername\sharename)
Good luck!
My Expert Contributions to the Discussion Groups: FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Deployment 32-bit
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am trying to put it on a portable harddrive... How do I get around Drive Letters for this?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
