Installation & Licensing
Deploying Multiple Autodesk 2014 products
1 REPLY 1
302 Views, 1 Reply
I'm looking to install 3 different Autodesk 2014 packages:  Inventor, Revit, and Autocad.  With the 2013 versions, we were able to make a deployment to install all 3 packages at the same time.  Is this possible with 2014?  Is there an "admin" install program to bundle the 3 packages together?
I could create 3 separate deployments, but was trying to bundle together.
Thanks.
1 REPLY 1
dembkod
sbrock,
Hello. There is no utility in the installer that allows you to wrap in other programs. That is, unless you have a suite with these programs as a part of the installer. Then you could just build one deployment package. As for third party options, there may be some available, they would just not be tested or supported.
 Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
