Installation & Licensing
Oleo1975
176 Views, 1 Reply
Delay in remote access
We recently added a 2nd office and files are all stored on our NAS box at our main office.  This has worked well locally, however when folks are remotely accessing the database there is a huge delay because of the limited upload speeds (5mbps).  There was thought of moving the files to the 2nd location but we then run the problem of which is the correct file.  The files aren't that large (3-5mg) however when changing tabs or saving it can take 3-4 min.
Any recommendations on how to overcome this....I'm sure this is a common problem with a semi easy solution.
1 REPLY 1
david.lau
in reply to: Oleo1975
What Autodesk products are you referring to?
David Lau
Administrator Productivity
